Pocket GPS World :: View topic - BeanBag for a TomTom 730. Sounds wise but which one?
TangoCharlie
PostPosted: Wed Jul 15, 2009 8:35 am    Post subject: BeanBag for a TomTom 730. Sounds wise but which one? Reply with quote
I have ordered a new car, a Mini Clubman. I don't want to give thieves any reason to break in so I though a simple bean bag dashboard thing would be a good idea for my 730 to sit on.
Can anyone recommend a decent one please? Obviously i don't want one that suctions on and it has to be relatively easy to remove from site.
Many thanks.
MrT
PostPosted: Wed Jul 15, 2009 8:57 am    Post subject: Reply with quote
I bought the Arkon version from blueunplugged, there used to be a discount code on this forum.
Many brands I have seen are from the same manufacturer but you probably need to get one with the suction mount included that mounts the x30 onto the bean bag as the original TT mount does not always give sufficient clearance below, especially when using the USB power lead. Try and position the original mount where you want the device on the dash and see if you have clearance, if it overhangs the front of the dash you may be OK, but if it is on a horizontal surface like mine you will need the mount part. It costs a lot more to buy them separately than together.
Drivelux
TangoCharlie
PostPosted: Wed Jul 15, 2009 10:16 am    Post subject: Reply with quote
Its confusing. Where does the suction mount sucker to?
Tc
"Keep it Simple, Stupid"
GerryC
PostPosted: Wed Jul 15, 2009 10:55 am    Post subject: Reply with quote
On of the bean bag is a plate that's just bigger than the suction cups that many major brands use.
The idea is that you can use the original holder that would attach to the windscreen but attach to this plate instead.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
TangoCharlie
PostPosted: Wed Jul 15, 2009 11:41 am    Post subject: Reply with quote
thanks.
Does this one look any good? looks pretty sturdy to me...
http://www.buybits.com/product/sku_5399.aspx
Tc
MrT
PostPosted: Wed Jul 15, 2009 1:39 pm    Post subject: Reply with quote
The buybits plastic mounting arm is the same as the Arkon but I do not like the shape of the bean bag as much as the Arkon. The Arkon thick part is in the shape similar to a large "U" with a flat at the front whilst the buybits is a square shape with no flat at the front.
The TT Bean Bag mount is the same shape as the Arkon and the picture of it on the TT site is much better at showing its shape. The TT version does not come with the mounting arm and costs a lot more.
Drivelux
Calomax
PostPosted: Wed Jul 15, 2009 7:40 pm    Post subject: Reply with quote
I have the one from blueunplugged without the suction mount
http://www.blueunplugged.com/p.aspx?p=135647 at £9.95. The original 720 mount is fine on it. Just came back from a holiday having done nearly 1600 miles and it stayed in place the whole time.
TT Go Essential
TangoCharlie
PostPosted: Wed Jul 15, 2009 8:42 pm    Post subject: Reply with quote
Thanx. Is the 720 very different to my 730?
rfp2001
PostPosted: Wed Jul 15, 2009 9:38 pm    Post subject: Reply with quote
720 & 730 series are same dimensions so both/either will fit the base unit. Simply use your suction arm on unit.
MrT
PostPosted: Thu Jul 16, 2009 7:30 am    Post subject: Reply with quote
The original base mount supplied with the Go x30 in a vertical position will not actually mount on a flat horizontal surface as the arm on it is too short. To mount on a flat horizontal surface either the Go must overhang the front edge or be tilted back to an angle. You then have to allow room for the USB plug to fit in the base.
See the picture below showing the clearance issue (red arrow) and also the taller Arkon mount which gives sufficient clearance for the x30.
Drivelux
Calomax
PostPosted: Thu Jul 16, 2009 8:38 am    Post subject: Reply with quote
Apologies then, the 730 mount is obviously different from the 720 because mine fits on the Arkon weighted mount with just sufficient clearance for the power plug.
TT Go Essential
MrT
PostPosted: Thu Jul 16, 2009 9:02 am    Post subject: Reply with quote
Likewise the x40 range standard mount is fine, I don't know if TT moved the position of the mount up the back on the x30 or if they made shorter arms on the later mounts. I would have thought many people would have wanted to use the mount on a horizontal surface such as a disk or bean bag.
Drivelux
Brickie64
PostPosted: Fri Jul 17, 2009 9:20 pm    Post subject: Reply with quote
It's a shame that someone can't come up with a bean bag type mount for the TT units that don't rely on suction. The Garmin mount seems a lot more reliable. I've had a few suction problems with my Arkon mount but it's probably a small scratch on the mount plate where the sucker attatches or the flexible plastic on the suction mount stem stretching. It's a real pain when the unit drops off the dash when driving !!
Gav
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-)
PostPosted: Fri Jul 17, 2009 10:58 pm    Post subject: Reply with quote
I'm sure it's not different, so there must be some other explanation.
PostPosted: Sat Jul 18, 2009 6:02 am    Post subject: Reply with quote
The EasyPort Mount for the x20/ x30 units does have sufficient clearance for the power cable on both units, as I recall the power cable for the x30 is slightly different to the ones supplied with the x20, the newer cable having the outlet pointing to the back of the device rather than the side - Mike
22.062 (12 Jun 24)
