Pocket GPS World :: View topic - Sygic Europe back in App store!
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
scarymonkey
PostPosted: Sun Jul 12, 2009 3:03 pm    Post subject: Reply with quote
Mike, do custom POIs not install the same way that you do with Windows Mobile based systems? Not having an Iphone I am working blind on how it works etc but can't really see a reason (unless Apple are dictating it) why the Iphone version should be different to the other Sygic Mobile based versions.
BTW in other versions, adding single POI create a poiname.upi file in the maps directory.
PostPosted: Sun Jul 12, 2009 3:38 pm    Post subject: Reply with quote
If I view the device using Windows Explorer I can see all the screen shots and photos I have taken with the iPhone but nothing else, when using the iTunes application I cannot find away to add anything to the device such as speed cameras.
Having just had a short (ish) drive around Blackpool I got warnings for nine of the eight cameras I drove at, the one extra warning was for a camera removed from the roadside about six months ago.
So the fixed camera positions installed with the application look good from an initial dip check.
Bear in mind Blackpool has loads of cameras, I would have driven further but its the Manchester to Blackpool cycle run today so the Prom and surrounding roads are grid locked! - will post up some screen shots from the application later tonight in this thread - Mike
scarymonkey
PostPosted: Sun Jul 12, 2009 3:49 pm    Post subject: Reply with quote
I wonder if this lack of easy add custom POI is a limitiation imposed by Apple or not? It does make the Iphone app a weaker one to the rest of the Sygic Mobile family though.
I am waiting on a version comparison direct from Sygic so will hopefully have this info sometime next week. Will be interesting to know what else is different (both good and bad).
One other big difference I can see is the postcodes since in WM putting spaces into the postcode prevents them from working properly. I wonder if the next release on WM will move to the Iphone way of working or the other way round?
gyre
PostPosted: Sun Jul 12, 2009 4:13 pm    Post subject: Reply with quote
The Europe version is far more expensive than the other versions they sell in the UK store for the iphone. Does anybody know if a UK version is expected to come out?
Thanks.
-- gyre --
ttrevor
PostPosted: Sun Jul 12, 2009 5:15 pm    Post subject: Reply with quote
Would be interested in the UK only if it did come out , but 1.8gb is a long download, how long did it take Mike??
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
PostPosted: Sun Jul 12, 2009 5:34 pm    Post subject: Reply with quote
Looking back at the MSN log when I was discussing this last night with one of the other Moderators I started it at 21:35 and it was complete by 22:05 so thirty minutes was the duration for the download, as I recall it took longer to actually transfer and install to the iPhone than it did to download! I do have a rather quick (50MB/s) Internet connection though via cable so bear that in mind as you might take longer depending upon your connection - half an hour isn't bad at all IMHO - Mike
J2b2
PostPosted: Sun Jul 12, 2009 7:04 pm    Post subject: Reply with quote
tip for you mike. speed cams. you just need to add the poi file into the same location on your iphone as the map is stored in. It uses the same format as McGuider.
PostPosted: Sun Jul 12, 2009 7:14 pm    Post subject: Reply with quote
But how? I can only view the contents of the iPhone's pictures i.e photos when using Windows Explorer and itunes doesn't help much either - an idiots guide might be handy as I don't have a Mac and don't intend to jail break the phone - Mike
classy56
PostPosted: Sun Jul 12, 2009 7:33 pm    Post subject: Reply with quote
Who's winning Mike, Navigon or Sygic? The burning question !
Tomtom Go730T
App 8.300
Map v815.2003
To old to die young.
Goober556
PostPosted: Sun Jul 12, 2009 7:43 pm    Post subject: Reply with quote
So jailbreak needed then.
PostPosted: Sun Jul 12, 2009 7:49 pm    Post subject: Reply with quote
Thats a no-brainer type question, Navigon works but doesn't get full use out of the GPS chipset leaving you without a position fix for long periods, very little in way of configuration to get the application to do what you you want.
Sygic on the other hand has the ability to hold on to the GPS signal in demanding conditions and has a whole host of options to play around with.
Bear in mind the above is a comparison made with the same handset in the same car with the device mounted in the same position, for some reason my iPhone is happy to keep hold of the GPS signal far easier running Sygic than Navigon
Whilst they both work and they both have certain rough edges Sygic is in a different class to Navigon, next I need to pull all the screen shots off the phone and get busy uploading them - might take a while.... - Mike
alan_dr
PostPosted: Sun Jul 12, 2009 8:49 pm    Post subject: Reply with quote
Mike, 1 quick question
When navigating, does landscape mode work both ways - whether you turn the phone clockwise or anticlockwise?
Alan - iPhone 5 64GB, with CamerAlert, TomTom Europe & CoPilot
J2b2
PostPosted: Sun Jul 12, 2009 9:09 pm    Post subject: Reply with quote
not sure if jailbreak is needed or not for the method i used.
I pmed mike how to do it if its acceptable he can post it here.
PostPosted: Sun Jul 12, 2009 9:23 pm    Post subject: Reply with quote
OK So its time for some screen captures so you can have a look at whats offered by this application:
First off is the Splash screen you get, followed by the "Nag" screen which takes around 10 seconds to appear
Main Menu only consists of two screens:
If you select Navigate To you get two screens of options
Next up are the Three pages of Settings:
Advanced Preferences
If you want to use the built in speed cameras first you need to switch on the warnings:
There are loads of other options available, but whats shown above should give you some idea of the menu structure, well thought out and logical in use, one that did catch me out though:
If you tap the globe sign on the keyboard you get a rather strange keyboard display, tapping it a second time and it goes back to a standard UK format - Mike
ttrevor
PostPosted: Sun Jul 12, 2009 9:31 pm    Post subject: Reply with quote
Thanks for that Mike, looks alot more advanced than Navigon ,do you think they will bring out UK only ? as i don't think I will be going further afield ,not in my car anyway.
Page 3 of 8
22.055 (29 May 24)
