SSR Frequent Visitor
Posted: Sun Jul 12, 2009 9:06 am Post subject: |
The Lite version just allows you to try before buying, as I understand it. |
twotonemark Regular Visitor
Posted: Sun Jul 12, 2009 9:55 am Post subject: |
At least with the Lite version you can check out the quality of the map data all be it in demo. _________________ iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
zebsogo Regular Visitor
Posted: Sun Jul 12, 2009 9:59 am Post subject: |
Navigon Lite...Are you kidding me... Seems like i must have bought the lite version as the GPS barely works anyway _________________ --
Navigon 92 Premium Live,TomTom Go 6000,Garmin 2699 LTM-D and a TomTom Go 1005 Live ( For the wife )
Posted: Sun Jul 12, 2009 10:01 am Post subject: |
twotonemark wrote: | At least with the Lite version you can check out the quality of the map data all be it in demo. |
YEAH but you cant't check out the quality of the GPS which is of crucial importance. Seems like Navigon are pulling a fast one here _________________ --
inthe128 Pocket GPS Verifier
Joined: Nov 27, 2005 Posts: 130 Location: Czestochowa, Poland
Posted: Sun Jul 12, 2009 10:02 am Post subject: |
They did they that the wrong way around then I got my full (sort of) full version some weeks ago _________________ in the 128 |
Posted: Sun Jul 12, 2009 10:26 am Post subject: |
It's just pulling the GPS data from the phone though. Theoretically the "quality" should be unchanged between app, no? |
wise1 Occasional Visitor
Posted: Sun Jul 12, 2009 12:10 pm Post subject: |
Having seen the crazy way apple are handling app store approvals it wouldn't surprise me if navigon submitted this for approval first but ended up with the full version "approved" first |
Posted: Sun Jul 12, 2009 12:28 pm Post subject: |
SSR wrote: | It's just pulling the GPS data from the phone though. Theoretically the "quality" should be unchanged between app, no? |
This is true but last night I installed Sygic to my iPhone, with the same phone in the same position fitted in my Ovlov it works fine, when running Navigon it loses the GPS signal more often (as mentioned earlier in this thread as I recall) - Mike |
Posted: Sun Jul 12, 2009 12:42 pm Post subject: |
From reading different forums about different apps that use GPS there seems to be a pattern of folks saying GPS is ok with app X but since 3.0 not so good with app Y. Very strange....most advice I've seen including Navigons is to do a backup and then erase all data and settings and do a restore. But then you see some folks say that helped and others who see no change.
I wonder if the case you have on your iphone in will have an impact considering where the GPS receiver is located on the iphone?
I'm trying hard to resist buying Navigon or Sygic and hold out to see TomTom released and reviews of both app and hardware.
I'm using an app called RunKeeper for jogging and don't find the GPS strong. _________________ iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
Posted: Sun Jul 12, 2009 12:49 pm Post subject: |
My Navigon or iPhone was pretty good on the 2,600 km trip it got used for. My iPhone charger does not have a long cable, so it sat in the ash tray down by the radio, no drop out at all, that did surprise me as a couple of GPS apps do drop out when the iPhone is in that position. Something that did surprise me is it kept its hold even going through the tunnels under Berlin when the TT gives in. _________________ in the 128 |
Posted: Sun Jul 12, 2009 12:51 pm Post subject: |
Maybe there's inteference from background apps, although I thought one of the iPhone's advantages is that it doesn't get bunged up with the stuff? Versus say Windows Mobile.
A major variable is the environment of course, and that may well cloud things, no pun intended.
Ditto on holding back for TomTom. I'm finding it a struggle, and am hoping the wait will be worth it... Traffic (presumably HD Traffic for the iPhone) is a key feature for me, although a lack of custom PoI's will be a blow. |
marcol Occasional Visitor
Posted: Mon Jul 13, 2009 9:04 pm Post subject: |
Some pics of the forthcoming Navigon update:
http://www.flickr.com/photos/navigon/
I think I'll hold on for this and to take a look at whatever else is around the corner, tempting though Mike is making Sygic sound. |
zebuk Occasional Visitor
Posted: Mon Jul 13, 2009 10:53 pm Post subject: |
I now have Both Sygic Europe and Navigon europe on my iPhone. I can honestly say that my iphone does not have a GPS issue or my location is a problem. For navigon to suggest (as well as Apple ) to more or less wiping your iphone and then re-sync it, is desperately clutching at straws to explain that it is not their software / hardware that has the issue
I took my iphone out in the car and did the same journey first with Navigon. It took an age to get the GPS signal and was slow to reroute me when taking a different turn to the routed one.
I then took the journey again using Sygic. The GPS locked on in seconds and was very very fast to reroute me when taking the detour.
I have been saying Navigon was pants since a bought it and am still convinced of this even more so now I have Sygic |
Posted: Mon Jul 13, 2009 11:07 pm Post subject: |
zeb, what you describe is the same as I have found for some reason Sygic is quite happy to provide a position fix where the Navigon app simply doesn't bother.
Keep an eye on the current speed indication when using Sygic and you will notice its far from accurate at times suggesting far lower values than actual if you are accelerating, conversely when braking the speed takes quite some time to reflect the true speed of the car - Mike |
bedbug Frequent Visitor
Joined: May 10, 2006 Posts: 484 Location: Hampshire, UK
Posted: Mon Jul 13, 2009 11:21 pm Post subject: |
Not my area of speciality, so forgive me if I'm suggesting the obvious...
Has anyone evaluated the GPS performance with as much as possible switched out - I mean no WiFi, no 3G, no bluetooth, no notifications etc.
I'm not suggesting reducing the hardware functionality for day to day use, but simply to test performance by reducing the load on the iPhone processor
Also, has anyone done a soft reset (or whatever it's called by Apple) to clear the memory? I have iStat for iphone and am amazed at the improvement to subsequent performance whenever I use the 'free memory' function, which is much faster than the power-off reset thingy.
I keep coming across references to the fact that GPS functionality is adversely affected by a phone that's busy doing other things. The most recent reference to this (that I read, not most recent posted) comes from the guy that codes OSMTrack for the iPhone Here.
It's no doubt possible to code different apps in different ways, which may explain a consistent difference in performance from one vendor to another, but my reading here seems to suggest different people are getting different results from the same hardware and software application combination, so this suggests either variation in geographical environments, or variation in the OS's impact on the application code. _________________ iPhone 4/4S (iOS 5.1.1); TomTom Western Europe (1.10)/USA & Canada (1.10); CoPilot for iPhone (8), UK mapping, Mac OS 10.8/XP Pro/Win7; Tongue firmly in cheek! |
