Steveee Lifetime Member
Joined: Dec 16, 2003 Posts: 203 Location: Colchester, Essex
Posted: Wed Jun 17, 2009 8:42 pm Post subject: GO920 not working following instructions from TT Support |
I reported the screen rebuild problem to TT Support. OK, I know I shouldn't have done it, but I followed their guidance and now my GO920 will not work
I did make a backup, but even installing that, I still get stuck at the 1st splash screen or at the TomTom logo after the drum roll
Also if I try to operate in TT Home I get the error message:
Error calling method on NPObject!
Any suggestions? _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
Darren Frequent Visitor
Posted: Wed Jun 17, 2009 8:47 pm Post subject: |
How did you make the backup? Manually or via TT HOME? _________________ Darren Griffin |
Posted: Wed Jun 17, 2009 8:54 pm Post subject: |
Manually. I have copies of 8.351, 8.350, 8.302, 8.301 as well. _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
Posted: Wed Jun 17, 2009 8:55 pm Post subject: |
What did TT tell you to do? _________________ Darren Griffin |
Posted: Wed Jun 17, 2009 8:59 pm Post subject: |
They said:
Quote: | STEP 1 - Creating a Manual backup of your TomTom
IMPORTANT: Please only continue with Step 2 if you have made a complete Manual back up of your TomTom without any error messages. If you do get an error message, please contact us before continuing.
STEP 2 - Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom drive (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Please make sure that quick format is not selected.
• Click on start.
• Once the format is complete, use the ‘Safely Remove Hardware’ icon in the bottom right hand corner of your computer to disconnect your TomTom from the computer.
• Once disconnected, your TomTom will show a red cross.
• Reset the TomTom for 30 seconds.
STEP 3 - Restore the Folders to the TomTom
• Connect your TomTom back to the computer and switch it on.
• Go to your backup folder in My Documents, double left click into it.
• Copy the following folder back onto your TomTom
1- Your map folder(usually labeled Western and Central Europe or United Kingdom and Republic of Ireland)
2- The folder named 'zip'(United Kingdom and Netherlands only)
3- The folder named 'raster'(applicable on only some devices)
4- The folder named 'loqendotts' (applicable on only some devices)
5- The folder named 'ASR' (applicable on only some devices)
6- The folder named 'Vocalizer' (applicable on only some devices)
•Now disconnect your TomTom by using the ‘Safely Remove Hardware’ icon again.
STEP 4 - Now we need to delete the application files from your PC so that HOME will offer them as an update
• Click on Start in the bottom right of your PC
• Now select My documents - TomTom - HOME - Downloads - Complete
• Please delete the yellow Program folder.
STEP 5 - Update your device
• Connect your device to the PC and turn it on.
• Open TomTom HOME: Start-All Programs-TomTom-TomTom HOME 2.
• HOME will now load your updates (If this does not happen automatically, click on Update My ONE on the main menu of HOME.)
• Make sure that only the application is marked with a green tick.
• Click on Update and Install.
• Once Installed, click on Done.
• You will now be prompted by HOME to restart your Device, just click ok.
• In the Top left of HOME, click on 'Device - Disconnect Device'.
• Now please disconnect your TomTom from the computer and allow it to start up normally.
If you get “No Maps Found” on your TomTom, please repeat Step 5.
STEP 6 - Run the Clear Flash Tool Twice
• Close HOME. (Make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen)
• Connect your TomTom to the computer. If it ask’s if you want to connect, please select yes.
• Download and run the clear flash tool from :
Now disconnect your TomTom (Safely Remove Hardware in the bottom right hand corner)
The Application is now installed, all corruption will have been removed and your TomTom will now be working normally again.
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Wed Jun 17, 2009 9:19 pm Post subject: |
If you still have backups then I would connect the device to the PC - exit HOME completely and then format the TT again.
Now start HOME and download any application that is offered or you have already downloaded and is in the Items on my Computer bit.
Disconnect from within HOME and see if it boots.
If it does, exit HOME completely again and then reconnect the device to the PC.
Now copy one of your backups over (from your backups I would go for 8.302) and overwrite all files.
Start HOME and disconnect the Device |
Posted: Wed Jun 17, 2009 11:26 pm Post subject: |
Thanks for the support. Followed Andy's suggestions and all is now coming clear. Installed 7.481, then replaced with 8.302 from backup.
All worked well, but obviously no map.
When WCE backup installed, all stopped working.
Looks as though there is something corrupt in the backup. Now installing WCE from TT Home. Still greater than 1hour to go.  _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
DennisN Tired Old Man
Posted: Thu Jun 18, 2009 12:41 am Post subject: |
Y'know what's terrifying? This is the Nth similar set of instructions starting with backup not using Home, but using Windows Explorer (although TT never actually use the name). Even TT seem to realise that Home is useless for backups, yet how many innocents out there are blithely following Home's advice to backup before downloading the new maps or apps.
The frightening part is that (including the 7 part set I followed myself two days ago - it didn't kill my 920, but nor did it cure my "challenge" either!) each one of the sets I've seen recently is different!! In order to achieve the same result - a nice clean TT with latest application and map, all working beautifully - different support staff select different instructions. And in MY case, those instructions fell over at the very first hurdle, because the Vista process is different from the Win XP et al processes - mine said "Start ... My Computer" and in my Vista machine, there is no My Computer under Start. Nor is there a "My Documents". Part of the "submit a question" process on the TT support website is to enter your operating sytem details!
I'd be interested to hear anybody's theory on the value of running Clearflash twice as the last stage after doing checkdisk, full format and reinstall.  _________________ Dennis
Two of them are obesiting!! |
Posted: Thu Jun 18, 2009 8:10 am Post subject: |
OK, following a reinstallation of WCE map from TT Home everyting is working again.  _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
Calomax Lifetime Member
Posted: Thu Jun 18, 2009 9:14 am Post subject: |
DennisN wrote Quote: | my Vista machine, there is no My Computer under Start. Nor is there a "My Documents". | Dennis, under Start, my Vista laptop has "Computer" and "Documents" along with "Music", "Photos" etc. In my case, Vista has just dropped the word "My". _________________ TT Go Essential |
Posted: Thu Jun 18, 2009 9:29 am Post subject: |
Yes, I know that, but put yourself in the position of somebody who has just been given their first satnav and computer and doesn't know from beanz - it doesn't say MY computer, nor MY documents and you're already scared stiff of the damned machine.
With remote assistance it's imperative to get it right or the person on the receiving end loses confidence and the person on the sending end can ask "simple" questions which totally throw the other person - sender needs to convince receiver they are both looking at exactly the same screen. _________________ Dennis
Posted: Thu Jun 18, 2009 12:19 pm Post subject: |
Got you now Dennis. I thought you meant they were missing altogether and though that one oldie might be ab le to help another oldie out. _________________ TT Go Essential |
Posted: Mon Jul 06, 2009 4:14 pm Post subject: |
OK, latest step in this saga!
TT Support asked me for a snapshot of my system information. After a few days they stated. Quote: | It appears that there is an issue with the map that you currently have installed on your TomTom. |
They then proceeded to take me through their previous instructions, including reinstalling the map.
I pointed out that as a result of their 1st set of instructions (when the TT would not restart) I had to reinstall the map from their server as my backup appeared to have a corrupt file. I asked them whether the server copy of the map is introducing the issue?
Still waiting for their latest suggestioon.  _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
bullyterrier Regular Visitor
Posted: Tue Jul 07, 2009 8:29 am Post subject: |
I had a similar set of instructions, after complaining about the flickering screen when the RDS TMC is connected. After following their instructions to the letter my 720 would say no maps found. So I replied to support and they wanted to know my units seriel number so they could start the proccess of returning it. So I asked them what would be the point of returning it if it is a software problem. Never got a satisfactory answer, just saying the most important part of tomtom is the maps. |
Posted: Mon Jul 13, 2009 3:52 pm Post subject: |
Still waiting for a response fro TT so did a little experimentation of my own. I noted that the screen redraw stopped when I disconnected TDS-TMC.
I have added this comment to my TT Support case. Waiting to see if they respond to this further update. _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
