Pocket GPS World :: View topic - Lost poi.gpi file on i3
eddie7
PostPosted: Tue Jun 30, 2009 8:19 pm    Post subject: Lost poi.gpi file on i3 Reply with quote
Hi,i backed up my micro sd card to my pc so i could renew it,but when i coppied the files to my new micro sd card i somehow erased the poi.gpi file,can anyone tell me where i can get this file from as i now have no poi's and cant load any to my i3,any help please?
PaulB2005
PostPosted: Tue Jun 30, 2009 10:22 pm    Post subject: Reply with quote
The poi.gpi file is just the Custom POIs you downloaded and installed yourself. It doesn't normally exist on any Garmin device out of the factory.
Can you not just re-download the files and recreate the poi.gpi file with POILoader?
eddie7
PostPosted: Tue Jun 30, 2009 11:03 pm    Post subject: Reply with quote
i cant install any poi's at all and the poi folder is not on the sd card anymore so i not got even the preset poi.s that came with my i3
PaulB2005
PostPosted: Tue Jun 30, 2009 11:09 pm    Post subject: Reply with quote
OK you'll need to provide more info.
Why not? What happens when you try? Error messages etc
and the poi folder not there anymore
At the minute I'm assuming this is the x:\garmin\poi folder? If so, just create it. If not, what is the exact path of the folder?
As far as I'm aware the preset POIs are part of the map data and are not deletable.
My old i3 backup shows just the following files.
In the root folder is a folder called Garmin which contains 2 files
gmapsupp.img (Map file)
gmapsupp.unl (Unlock File)
then a folder called poi which contains nothing as it's there for the Custom POIs you add only.
then a folder called voice which contains various voice files.
How does this compare to your unit?
eddie7
PostPosted: Tue Jun 30, 2009 11:17 pm    Post subject: Reply with quote
i have deleated the poi folder but now have no poi's on the unit at all,and when i use poi loader it says completed but adds nothing ti the unit
PaulB2005
PostPosted: Tue Jun 30, 2009 11:33 pm    Post subject: Reply with quote
So what DO you have on the unit?
Apart from the POIs does it work normally?
eddie7
PostPosted: Wed Jul 01, 2009 12:27 am    Post subject: Reply with quote
The unit seems to work fine its just not got any poi's,which i used to rely on for fuel/accomadation when travelling etc
PaulB2005
PostPosted: Wed Jul 01, 2009 7:34 am    Post subject: Reply with quote
So what files DO you have on the unit?
Did you try making the POI Folder as i suggested above?
What do you see if you try to Navigate to a POI? You'll need to list the exact steps you take and what happens as i don't have my i3 any more....
Can you also answer this question from earlier?
BigPerk
PostPosted: Wed Jul 01, 2009 8:33 am    Post subject: Reply with quote
In the POI folder on your PC that you specify to POILoader to look in for your POIs that you want downloading to your unit: Are your POI files there and do they have actual POI data in them?
Or is this one of the files that you deleted/cleared?[/u]
(Navigon 70 Live, Nuvi 360)
eddie7
PostPosted: Wed Jul 01, 2009 8:13 pm    Post subject: Reply with quote
x:\garmin\poi was the folder i deleated the poi.gpi file from,i have tried re creating it and using poi loader to put poi's on the unit,folder on my pc specified for poi loader does contain poi's and they contain datawhen i search for poi's on the unit it says no results in any poi catagory
22.063 (19 Jun 24)
