Simmo11 Occasional Visitor
Posted: Sun Jun 28, 2009 7:08 pm Post subject: Best Sat Nav Which I Can Take Out of The Car for Use on Foot |
Could anyone recommend the best sat nav system that I can use in my car, then take out for use in towns and in the country?
Cheers |
Andy_P Pocket GPS Moderator
Posted: Sun Jun 28, 2009 7:15 pm Post subject: |
If you want to use it for walking ACROSS country, none of the sat-navs intended for car use are that great.
They all tend to have road maps only and the system will attempt to "snap" you onto the nearest road when you go wandering off them.
THIS TOPIC from a couple of weeks ago recommends one good for general use and geotagging.
THIS ONE might be of use too, and if you want to load OS mapping have a look at THIS ONE. |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sun Jun 28, 2009 10:21 pm Post subject: |
Quote: | then take out for use in towns and in the country? |
If you don't
Quote: | want to use it for walking ACROSS country |
you'll find most have a 'Pedestrian' mode, which will route you the 'wrong way' up one way streets for example and through pedestrianised areas.
The main problem is batteries only last between 2 and 4 hours.
I use mine e.g. Park up in a strange town, mark with a Pin and add as favourite. Walk around and then start sat nav, set to Pedestrian mode and route to push-pin or favourite. Never failed me yet.
With mine, if I forget to re-set to car mode it warns me. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Leigh_at_ch9 Occasional Visitor
Posted: Wed Jul 01, 2009 2:46 pm Post subject: |
Oops. Please ignore this.
Posted same msg twice
Leigh
Posted: Wed Jul 01, 2009 2:47 pm Post subject: |
Simmo
I've just gone through the same process and I must say I agree with Andy. A device which is great for satnav and offroad use seems to be a rare beast indeed, if it even exists (you could poss look at a Road Angel on the Memory-Map site)
If u check out the last link in Andy's reply, that was me. I'll update u in case you're interested in going down that route. My Vodafone VPx / GPSlim combo is a great setup for not much money. It's classed as a phone, but it's a huge one with a screen the size of some satnavs. I run McGuider for satnav, and Memory-Map for offroad. Granted, Memory-Map is not cheap but I already had it for laptop use and it's cheaper than most of the OS mapping from the likes of Garmin / Satmap etc. Both apps run great on the VPx. Battery life can be a pain but if you make sure it's fully charged before venturing out and switch it off when you don't need it, the battery will last for an all-day walk easily, so not bad. I just need a car power cable for mine now (which I can't find at the moment) and it'll be superb. Without the 2 apps the PDA (or phone if u prefer) and GPSlim cost me around 80 quid in total.
Leigh |
MaDProFF Occasional Visitor
Posted: Fri Aug 28, 2009 9:56 am Post subject: |
I recently bought an HTC Pro 2 and co pilot 7, that has a walk mode that pin points where you are, and not snap to nearest road.
it seems to work well, though ofc only as good as the map it is reading.
The battery lasts quite a while as well, even longer if you set up the phone correctly to suit, and use the night map. |
