navtrav Regular Visitor
![](http://www.pocketgpsworld.com/images/compass.jpg)
Joined: 03/01/2003 19:00:24 Posts: 122 Location: United Kingdom
Posted: Fri Jun 26, 2009 11:43 am Post subject: moving POIs into categories |
How can I transfer all my different camping/aires POIs on my 730GO into one category. In fact will doing so help?
For example, when I click on 'find nearest supermarket' I get a list of all the major ones and how far away they are. How I managed to group them all together I'm not sure.
But that's what I want to happen when I click on say 'Camping'. I want it to then list whatever's nearby. I have separate POI files for CCC, CC, French aires and campsites, another lot for Spain and Archie's excellent all of Europe list.
Come towards evening, I haven't time to tell TomTom to search each file in turn? And that brings me back to my original question - how to group these different POIs under one search.
Any advice greatly appreciated.
Tim |
Posted: Fri Jun 26, 2009 11:47 am Post subject: |
Tim, you need to concatenate the various files in a single POI file for the device, to do this I use a PC application called POIEdit which is very easy to use, try a search for POIEdit or try Here - Mike |
MarkWorthington Occasional Visitor
Posted: Fri Jun 26, 2009 12:11 pm Post subject: |
mikealder wrote: | Tim, you need to concatenate the various files in a single POI file for the device, to do this I use a PC application called POIEdit which is very easy to use, try a search for POIEdit or try Here - Mike |
Another good one is an on-line version, http://www.poieditor.com |
Posted: Fri Jun 26, 2009 12:56 pm Post subject: |
Thanks Mike. I have now put a message on the PoiEdit forum asking how to use this software for this particular job. With no help advice except for an on-line FAQ, I can only gather it seems to be able to edit just one POI at a time. And then what?
Here's hoping their not-so-frequently used forum may come up with an answer in the not too far future.
Tim |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Fri Jun 26, 2009 1:14 pm Post subject: |
Open one of your POI files, then select File ... Append. You will be prompted to open another file, which will be added to your existing one. _________________ Garmin DriveSmart 50 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Fri Jun 26, 2009 5:28 pm Post subject: |
I do exactly that, every time I download the verifiers speed camera files. (Sometimes it is useful to have them as separate types, sometimes I want a single file with them all in).
So, the drill in POIEdit is:
"Open" the first file
"Append" the second file and all others one by one.
then "Save as..." the combined file with a new name. |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Posted: Fri Jun 26, 2009 9:12 pm Post subject: |
Then when you've done that you can ask it to find, select & delete any duplicates, then save the results as your one POI category. _________________ TT Go Essential |
Posted: Sat Jun 27, 2009 12:57 pm Post subject: |
Brilliant. Thanks one and all.
I did find that as it was such a big file the 'find duplicates' took more than two hours!
Hey, I've got the result I wanted.
Next I was wondering about a .bmp symbol. What I've done is renamed one of the symbols I was discarding after amalgamating the files to the name as that of my new mega-merged file.
Thanks again
Tim |
dhn Frequent Visitor
Posted: Sat Jun 27, 2009 1:25 pm Post subject: |
A little late, I guess...
But here's a link to an application that finds and deletes duplicates. _________________ David |
