Joined: Sep 24, 2006 Posts: 138 Location: Tamworth Australia
Posted: Sat Jun 06, 2009 12:01 am Post subject:
AndyVaughan wrote:
Moral of the story is add the Navcore on top of previous Navcores.
I ahve had no problems doing it the TT official way - If I put my day 1 backup on of 7.221 I get an update to 8.300, then 8.301, then 8.351 (I think - it may offer 8.350 as well).
This way no files are missing.
And that is the way I have done it. I do not use the SD card other than for MP3's. I formatted the unit, connected it up, took the first application and updated from there. Somewhere along the line, they have left out files. I agree with you Andy, update to main memory.
Regardless, any joy with the phone providers updates anyone, the unit is getting stuck as, I think, it is using old data when trying to establish a data network. It is connecting to the mobile, the mobile has authorised the connetion and it is connecting to the net.
Posted: Sat Jun 06, 2009 10:49 am Post subject:
Home doesn't recognise my SD card with 8.351
Until & including 8.350 I could have the o/s on an SD card & update the card via Home using a card reader. TomTom Home recognised the card, booted up & treated it in exactly the same way as it would my 520 but since I bit the bullet yesterday & allowed Home to update the SD card from 8.350 – 8.351 it is no longer recognised by TomTom Home. To confirm this I reverted back to 8.350 using my backup & let Home update to 8.351 again. Home then directed me to remove the card from the card reader, put it in the TomTom, switch on, boot, switch off & put the card back in the computer. Everything seems to be working, the 520 boots without problem but again Home no longer recognises the card.
Searching Help I found this:-
Note: SD cards used with GO x20, x30 or x40 navigation devices are not intended to be used separately in a card reader. Hence if you access one of these cards through HOME in a card reader, HOME will not recognise the card.
As a politician would say, I refer you to my previous answer
Why does everyone feel the need to run Navcores off of SD Cards??
Backup before an upgrade, update the internal memory and if you don't like it, roll back. You can always manually copy the backup to an SD card if you want the option of dual booting different Navcores.
Posted: Sat Jun 06, 2009 12:44 pm Post subject:
Does ‘everyone’ ?
I had a full backup hence I was able to roll back to previous o/s
AndyVaughan wrote:
HOME has always been flakey with SD Cards.
Is this your experience or ‘everyone’ as above. It certainly isn’t mine as I had no problem until now but my post was to illustrate an anomaly I had come across with Navcore 8.351, the subject of the thread. I am aware of the ongoing debate on the use of SD cards and I use one because:-
a. My TomTom seems to be smoother when running from a high speed SD card &
b. I usually update my TomTom at work & it’s much easier to do it via an SD card & reader than carry the cradle around
Unfortunately, whether I am right or wrong using an SD card & home in this way is now irrelevant as TomTom have now made it impossible, which is all I was trying to say in my original post.
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Sat Jun 06, 2009 1:08 pm Post subject:
I have just tried my HCSD card with tomtom navcore 8.351 installed.
I put the card into my card reader and TomTom Home did recognize it and allowed me to update to the card in the card reader.
How strange - tomtom does it again !!! _________________ Jonial
Posted: Sat Jun 06, 2009 1:15 pm Post subject:
Very strange, I even did the upgrade to 8.351 twice to double check that it wasn't a one off - I checked the root to make sure all the files are there & it's almost identical to 8.350 with nothing missing as far as I can see. I'm really scratching my head now so I'll try a manual install later
UPDATE:
I've just rolled back to 8.350 & done a manual upgrade to 8.351 & hey presto my SD card opens up Home again, so thanks to jonial for the info an apology to AndyVaughan as I have also now had problems with Home & SD cards.
Posted: Sat Jun 06, 2009 2:52 pm Post subject:
I can't speak for "everyone", but I do it because it's not possible to test every possible eventuality while in the vicinity of a computer. If I run into a problem with the new application while on the road I can easily remove the SD card with the new app, and run the tried and tested app from the internal memory. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
Posted: Sat Jun 06, 2009 3:00 pm Post subject:
Exactly the same reasons here. Having been caught out before by a couple of crap Garmin firmware updates (which can only be loaded to the unit and aren't always capable of being rolled back) which contained major problems and which weren't apparent until you were out on the road, i wanted to check things this way.
Plus it is easier to contrast two (or more) NavCores by swapping SD Cards in and out. From what i can see it used to be the way to do this but then TT made what appears to be an un-announced ommission of some folders.
Posted: Sat Jun 06, 2009 4:07 pm Post subject:
{snip}
But it was never a problem until 8.351 - Strange
{snip}
Just to confuse everyone even more....
I have to run my 720 totally off an SD card since the internal memory permanently corrupted/died a few months ago.
For a while, I could carry on using Home and telling it to use the SD card.
But now, in direct opposite to what TomTom say above, Home refuses to recognise the card UNLESS I use a card reader, even though Windows can see it fine.
Sticking it in a reader, doing the updates and then then following the instructions to put it back in the machine, boot up, shut down again and put it back in the reader if I want to carry on using Home, seems to work OK so far.
Admittedly, not 'everyone' runs Navcores off of SD cards.
I have had problems on and off through HOME with SD cards, so I always take it out when connecting to HOME.
Because of this I adopted the strategy of running everything off of the internal mem as TT originally designed.
Another reason for this is the constant troubleshooting I have been going through with TT support over the dubious handsfree functionality, and to save any 'excuses' from TT about because I am running off of the SD card etc I have stayed with everything on the internal mem.
I usually carry a copy of a different Navcore on SD card complete with maps for testing / comparison purposes, as well as an SD card full of mp3s with me.
I know others prefer to do it the other way round, old navcore on mem, new navcore on SD. Given the problems this can cause with file locations etc I prefer the other way round. This isn't the first release that has had files missing IIRC it might have been 7.481 or 7.221. The interesting thing is they were also 'minor' releases so were to address issues with the preceding 'major' release and were released within a matter of days.
This is fairly common practice that you have to have the previous 'major' release before patching with the 'minor' release. Or maybe TT did just cock up and miss some files out
Posted: Sun Jun 07, 2009 12:43 pm Post subject:
As mention earlier, I have got rid off some recent backups (next time onto a dvd!!). Where would any phone updates etc be stored on the tt unit? I still have an older back up on another drive, January this year, looks to have all the folders.
Just aside, perhaps we need a sticky with the complete list of folders a tt shoud be running. Something for people to check against if they suspect something might be missing.
The three files you need are connect2internet.so , connect2internetdb.ver and connect2internet.db
If you PM me your email address I will send you the version 15 phone database, which AFAIK is the latest.
The other culprit for phone problems is the contents of the ppp folder - you can safely delete the contents and they will be recreated when you pair your phone again.
Posted: Mon Jun 08, 2009 7:45 am Post subject:
orion_jb2001 wrote:
I have those 3 files but I also have a file named connect2internetdb.enc. What should I do with that?
Jeff
that other file seems to be one created as you do a bluetooth connection. I deleted the contents of the ppp folder, re paired the mobile and tt, but the tt did not create anything within that ppp folder. The tt set up ok for hands free but again stalled at the data connection. I have used the same mobile before sucessfully in data connection with the tt, before you ask.
