Gibbo10 Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_027.jpg)
Joined: Sep 21, 2008 Posts: 262 Location: Swindon, Wilts
Posted: Mon Jun 01, 2009 8:15 pm Post subject: |
If you have the very latest version of Satsync and import a pocket query (not one generated through my macro) straight into the A10 it should now divide the file into multiple files and load ok. |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Posted: Tue Jun 02, 2009 2:18 pm Post subject: |
I updated the Firmware and Satsync on Sunday evening (31/5/09) from the Satmap web site - I assume these are the latest versions.
I used the Geocaching.com Pocket Queries generator - it has been creating regular searches for me each week. I took the local one that loaded OK onto my Colorado 300 and then tried to Import it through Satsync. It correctly identified there were 400 locations - the progress bar then went to about 25%. An hour later I killed the job and started the reduction in size to see what would load. What version of Satsync should I be using? I did follow their instructions to remove the previous version prior to updating Satsynch (Why can't they do this themselves?).
I can PM you the original 400 point file if you like.
Cheers _________________ Phil |
Posted: Tue Jun 02, 2009 2:29 pm Post subject: |
Definately something wrong then, I'd say that you have the right version of it. I know that some people have got it to work. I've just sent you a PM with my email address. I'll try it on my version. If not I'll forward it to my contact at Satmap to check out. |
Posted: Tue Jun 02, 2009 8:26 pm Post subject: |
I'm told that Satmap are working to fix the problem that could be causing the issue that philpugh has, another version will available very soon.
Also, if you have upgraded to v1.2xx then you don't need to unistall every time you down load the next version but if you are on v1.023 you will need to do the unistall. |
Posted: Wed Jun 03, 2009 10:33 am Post subject: |
I would like to thank Gibbo10 for his 'behind the scenes' work. _________________ Phil |
