concretemike Occasional Visitor
Posted: Sun May 31, 2009 6:52 pm Post subject: Speed cameras and POI's fail to display on Nuvi 255W? |
I have been using the speed camera database and the free POI's on my Nuvi for some time. Today I decided to download a more extensive set of POI's and also installed the latest speed camera database. I also deleted the old free cyclops database off the unit.
Now nothing displays - no speed cameras no POI's - just the map and my favourites?? I know the POI's are loaded as I checked using exporer. they are in the right place on the Nuvi and are selected as display proximity points too? I also reloaded the free trial cyclops databse back again in case it was deleting that the screwed it?
Anyone got any ideas?
Mike Grantham |
Darren Frequent Visitor
Posted: Sun May 31, 2009 7:48 pm Post subject: |
Have you exceeded the limit? There is a limit of around 250 on your model IIRC.
Might be worth removing the lot and restarting with just a few to test? _________________ Darren Griffin |
Posted: Sun May 31, 2009 8:35 pm Post subject: |
Darren wrote: | Have you exceeded the limit? There is a limit of around 250 on your model IIRC.
Might be worth removing the lot and restarting with just a few to test? |
Thanks for responding Darren. I Tried taking all off and just putting the cameras on - still wouldnt show! Nor does the free trial Cyclops database from garmin - nothing but the map? |
Posted: Sun May 31, 2009 8:40 pm Post subject: |
Hmm, perhaps try a system reset? _________________ Darren Griffin |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Sun May 31, 2009 8:45 pm Post subject: Re: Speed cameras and POI's fail to display on Nuvi 255W? |
concretemike wrote: | Today I decided to download a more extensive set of POI's and also installed the latest speed camera database. |
How did you do this?
By default, POILoader creates POI.GPI, overwriting any previously existing file. So, if you run it twice in succession, you end up with the last thing you loaded.
You can avoid this, by either having one huge tree that contains all your files (so they all get loaded at once), or by renaming the POI.GPI to somethingelse.GPI after the 1st run.
(You can also use the 'Custom Folder' option and build the POI.GPI on your PC, then rename it before copying to your Nüvi.)
The way to 'know the POIs are loaded', is to find them in the Nüvi menu, select one of 'em and examine its details. (Where to? | Extras | Custom POIs ... etc)
and he wrote: | I also reloaded the free trial cyclops database back again in case it was deleting that the screwed it? |
No that's not related - except that it might confuse the issue, having double alerts for some of the cameras. (Not all the cameras...the cyclops database doesn't contain all the cameras ) |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Mon Jun 01, 2009 11:51 am Post subject: Re: Speed cameras and POI's fail to display on Nuvi 255W? |
concretemike wrote: | I know the POI's are loaded as I checked using exporer. |
did you just copy and paste the files using explorer? you need to use poi loader software to install them!
MaFt |
Posted: Mon Jun 01, 2009 12:01 pm Post subject: Re: Speed cameras and POI's fail to display on Nuvi 255W? |
MaFt wrote: | concretemike wrote: | I know the POI's are loaded as I checked using exporer. |
MaFt |
I did use the POI loader. Curiously I now have the poi's working - with icons showing but not the speed cameras (which always worked in the past). I could navigate to them though, as they show in the where to - extras bit - just not on the screen!
It's got me puzzled. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Mon Jun 01, 2009 12:31 pm Post subject: |
Perhaps an obvious question, but have you zoomed in enough on the map, to make the camera icons visible?
Dales. |
Posted: Mon Jun 01, 2009 1:25 pm Post subject: |
dales wrote: | Perhaps an obvious question, but have you zoomed in enough on the map, to make the camera icons visible?
Dales. |
Yes I have- the other icons are visible, so the speed ones should be too?
Thanks for reply though! |
Posted: Mon Jun 01, 2009 1:29 pm Post subject: |
Did you load the POIs and the Speed Camera at the same time or the Speed Cameras first and then the POIs? |
Posted: Mon Jun 01, 2009 2:44 pm Post subject: Speed cameras fail to display on Nuvi 255W? |
PaulB2005 wrote: | Did you load the POIs and the Speed Camera at the same time or the Speed Cameras first and then the POIs? |
I have, I think got to the bottom of this. The speed cameras are there as tiny icons (little blue spheres) rather than the 30mph, 40mph icons I have been used to. I am using the speed zone complete set and they always showed previously as the speed icon. Why they dont do so now is annoying. As it is, they arent obvious till you you are on top of them and dont give a warning unless you are exceeding the limit. |
Posted: Mon Jun 01, 2009 2:50 pm Post subject: |
I'm sure I recall that being a symptom of too many POIs. _________________ Darren Griffin |
Posted: Mon Jun 01, 2009 3:33 pm Post subject: |
Darren wrote: | I'm sure I recall that being a symptom of too many POIs. |
Thanks Darren. I'll try knocking off some of the newly loaded ones and see if that helps! |
