Pocket GPS World :: View topic - will having my a10 in my rucksack/case affect gps signal
howard40uk
PostPosted: Sat May 30, 2009 11:25 am    Post subject: will having my a10 in my rucksack/case affect gps signal Reply with quote
just wondering if having my a10 in the case or in my rucksack will gave any affect on performance of the a10
cheers
PostPosted: Sat May 30, 2009 11:41 am    Post subject: Reply with quote
Unless you have a lead lined rucksack the device will be fine stored in it!
I tend to use the supplied case for the device and wear it on my belt, this makes it easier to get at when walkng, has your new toy arrived yet? - Mike
howard40uk
PostPosted: Sat May 30, 2009 11:51 am    Post subject: yes mike Reply with quote
yes mike just arrived and about to set off on my first walk with it ,can u tell me mike when ive done my walk how do i end the route and and save it .also ive read if i stop for a break how do i pause it so it dont add distance to the route as ive read it does sometime id u stop for long breaks
hope u can help
thanks
PostPosted: Sat May 30, 2009 12:03 pm    Post subject: Reply with quote
At the end of your walk go to the Routes Menu and select Convert Trail to Track, you can now name the file and save it to either the SD card or the internal memory.
If you ever fancy a walk around the Garstang area one weekend/ evening let me know and you can try my 25K scale maps of that area, at least you would then be able to judge what the difference is on the device while out and about. My 25K scale doesn't go as far East as where you are located - Mike
howard40uk
PostPosted: Sat May 30, 2009 12:53 pm    Post subject: Reply with quote
Hi yes will do a walk with u no probs .im round hougton bottoms at the moment i see the red dots on the screen as i walk but it still says planning at the top and ive a blue circle following the track and a red one that i can move about the screen is this correct or should the red one not be there .
PostPosted: Sat May 30, 2009 12:59 pm    Post subject: Reply with quote
You have the device in planning mode to put it in to GPS mode press the large button to the left of the cursor. If you knock the cursor it will drop out of GPS mode and go to Planning mode, if it doesn't say "GPS Map" at the top of the screen its not in the correct screen.
You get used to this after a while, but knocking the joystick which drops it out of GPS mode is my only real niggle with the device - Mike
howard40uk
PostPosted: Sat May 30, 2009 1:22 pm    Post subject: Reply with quote
Yes im in gps mode now and locked the keypad .the distance ive done is im km can i change it to miles .thanks for your help m8
howard40uk
PostPosted: Sat May 30, 2009 5:21 pm    Post subject: Reply with quote
Changed it to miles and feet im the settings comes up 6.13 miles but only walking for 1.06 hours i did way over 2
jonesbach
PostPosted: Sat May 30, 2009 6:29 pm    Post subject: Reply with quote
Curious, what average speed is shown?
howard40uk
PostPosted: Sat May 30, 2009 7:01 pm    Post subject: Reply with quote
Well im in pub now but i dident run round Laughing Out Loud maybe im wrong ill check again when i get home .but ill meet u for a walk soon and u can show me how to use it if u dont mind doing so
22.062 (12 Jun 24)
