JohnDough Occasional Visitor
Posted: Fri May 29, 2009 9:38 pm Post subject: Navigator 6 on Dell Pda |
I have a old sd card with navi 6 and put it in the slot but it says not suitable for pocket PC.
It was used previously on a Acer N30 no problem so have I done something wrong? or perhaps I do not understand these things being a old codger!!
thanks for any assistance.
BTW Great forum this.  |
Posted: Fri May 29, 2009 9:47 pm Post subject: |
Pop the card into the PDA and use File Explorer on the PDA to view the contents of the SD card, there should be a folder named "2577" open this and tap the CAB files in the folder IIRC there should be two of these. This will install the application to the PDA - Welcome to the forum BTW - Mike |
Posted: Fri May 29, 2009 10:12 pm Post subject: |
Cheers Mike thanks for a quick reply |
Posted: Fri May 29, 2009 11:36 pm Post subject: |
Ok got it going after changing the cab file (there were 2 in the 2577 folder) Now the problem is the voices will not work for some reason, there are 2 UK 2 US and 2 "Aussie " but it says "voices have not been loaded"and it will not test either, they are greyed out..
Mapping is ok and gps locks on so getting there slowly.  |
