fxgopher Occasional Visitor
Posted: Mon May 25, 2009 7:04 pm Post subject: 510 - won't charge - seems loose in mount for some reason |
My 510 isn't charging when it's in the car mount.
The green light comes on the the 12V adaptor & the unit, but the charge indicator just shows a bit of green, not that it's charging. (if that makes any sense)
If I wiggle it, then sometimes it say's charging, but then reverts to the above.
Before I get mad & throw it at someone, has anyone any suggestions as to what the problem is, I'm thinking I may need a new mount for it.
Frank Xerri |
sausage27 Occasional Visitor
Posted: Fri May 29, 2009 11:36 am Post subject: |
My 910 has just started to have the same problem. Light is on when on the cradle but is not charging.
If I hold it the 910 down onto the cradle then it starts to charge again. I get the same on the home dock/charger so it's probably not the mount. I have tried to clean the contacts but it hasn't made any difference.
I was looking at buying a new mount but at 30 quid they are not cheap - but as I said it may not be that anyway.
Peter |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Fri May 29, 2009 11:43 am Post subject: |
If its playing up on both the car mount and the Home dock its probably the connector strip in the device, to change this would mean a new main board which is probably going to cost far more than the device is worth - Mike |
pdauser Occasional Visitor
Posted: Fri May 29, 2009 12:15 pm Post subject: |
I had the same problem with my tomtom gps receiver, the charger's round pin type connection simply became loose, which in effect makes the item redundant. I hope the new usb socket on my 930 proves more reliable.... |
