howard40uk Occasional Visitor
Posted: Tue May 26, 2009 10:52 pm Post subject: help me transfer my satmap routes to memory map on my pc |
i have the 50 maps on my satmap and memory map on my pc is there anyway i can trasnsfer my satmap maps to memory map so i can print my routes out .can u alsp transfer my convert routes from memory map so the can go on my satnav
thanks |
nonoftheabove Regular Visitor
Posted: Wed May 27, 2009 7:46 am Post subject: |
open Memory Map for starters.
click OVERLAY on the top banner header.
select import.
( note folder where files are stored ) and select folder and file required
Note file type required and highlight that option
So we have Walk.gpx [for example]
select this and bingo it should be present and showing on the screen superinmposed on the map ; from there one can then look at the profile etc.
hope that helps. |
Posted: Wed May 27, 2009 10:05 am Post subject: |
Hi thanks for help . But also if i plan a route on memory map can u transfer the track to my satmap not sure if this is possible .cheers |
Posted: Wed May 27, 2009 10:21 am Post subject: |
as to your last question. I dont see why not
Personally I have never transferred routes from Mem Map to Satmap.
I have planned plenty of routes on Mem Map though and then printed them out and taken a paper copy[ screen dump] on my walk- along with OS map somewhere in rutsack and Satmap logging walk.
But each individual has different needs from/with the device in question. |
Posted: Wed May 27, 2009 10:59 am Post subject: |
Ive just ordered my satmap and just wanted to know if it could be done as it may come in used to me at some point putting routes off memory map on to the a10 |
Tony_P1 Occasional Visitor
Posted: Wed May 27, 2009 11:15 am Post subject: |
Just save the memory map route to your PC in .gpx format, then import the saved file into the A10 using Satsync. Works a treat.
Tony |
Posted: Wed May 27, 2009 11:23 am Post subject: |
Thanks for your help the a10 looks a cracking device if the route distance walked is also accurate which im not sure about this will be money well spent .just bought the lancashre 50k area map too so cant wait till it arrives |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Posted: Wed May 27, 2009 2:51 pm Post subject: |
Tony_P1 wrote: | Just save the memory map route to your PC in .gpx format, then import the saved file into the A10 using Satsync. Works a treat.
Tony |
Just to stress the very important word in Tony_P1's reply - it's IMPORT. This is the option on SatSync that converts a .GPX file into a .MAP file that the ACTIVE 10 uses. If you just copy the .GPX file - nothing happens - except you have a bit less storage available ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ Phil |
