Pocket GPS World :: View topic - POI-Warner help please?
Goto page Previous  1, 2, 3, 4, 5, 6  Next
dougproctor
PostPosted: Fri May 22, 2009 7:05 pm    Post subject: Reply with quote
Thanks David. Give it a go tomorrow and let you know how I get on.
Doug
Returned to a proper Garmin although still have Co-Pilot on a Galaxy S3!
OddJobMan
PostPosted: Fri May 22, 2009 8:08 pm    Post subject: Reply with quote
Is there anyway of saving the settings or making a back up of the settings? Last thing I want now is to suffer a flat battery and have to start programming all over again
Garmin 710
Navigon 2150max
BigPerk
PostPosted: Fri May 22, 2009 10:05 pm    Post subject: Reply with quote
I'm pretty sure all the info is stored on the sd card.
(Navigon 70 Live, Nuvi 360)
Pocketgps
PostPosted: Sat May 23, 2009 2:33 am    Post subject: Reply with quote
On the Mio168, and Medion PDA I can use Active Sync to do a full backup.
My Medion PND will not for some reason backup via Active Sync.
On all of my gps units (Mio168, Medion PDA, Medion PND), the main POI-Warner app is stored in the Ram Disk by default. That's why you may loose all the settings if the batt goes flat Crying or Very sad
That may not apply to different gps units.
BigPerk
PostPosted: Sat May 23, 2009 4:57 pm    Post subject: Reply with quote
Pocketgps is right again Cool ! I have the 8110 which seems to be the only one in the range which uses an sd card. I assume however Rolling Eyes that files, inc POI-Warner, in the RAM on the other models show in the standard file structure when connected to your PC and can be copied onto the PC's hard disk ok?
OddJobMan
PostPosted: Sat May 23, 2009 5:19 pm    Post subject: Reply with quote
Yes I am thinking back to the time I had a Medion PDA and settings went when battery went flat. So hopefully settings with POI Warner are now on the sd card .
Garmin 710
Navigon 2150max
dougproctor
PostPosted: Sat May 23, 2009 7:49 pm    Post subject: Reply with quote
Hi Pocketgps and David,
Think I have cracked it at last! Under POI Warner General options, I have an Activate POI Direction option. This gives you a disabled, display on map and warn and display on map only. It was disabled because I thought it meant stopping speed cameras showing when they were facing the other direction.
After changing to display on map and warn, up came their speed cameras which I have, at last, managed to download and activate. I think they had not activated my account because I was told to put my user name in POI-Warner and do a a synch. They were installed. On a run out, got the Navigon warning and countdown.
I have now left them on the unit but deselected them and put the PGPSW ones with the WAV warning files on there. Going to give it a run tomorrow and see if they come up. If not, I can always switch them over with the POI-Handler ones which I know work. I also have downloaded some speed cameras from POI Plaza as well just incase all the others spontaneously combust!!
Hopefully all should be okay now, I have at least one set that I know works.
Thanks again
Doug
dougproctor
PostPosted: Sun May 24, 2009 5:13 pm    Post subject: Reply with quote
Got the warnings but did not get the sound warnings! Got the attention - Achung etc even though I have the 8 bit sound files in the POI-Warner directory and have them selected.
Definitely getting there ----slowly.
Doug
BigPerk
PostPosted: Sun May 24, 2009 8:05 pm    Post subject: Reply with quote
Hi Doug, glad to hear of your progress. Hope you didn't pay too much for the Plaza database though - from what Darren on here says it seems to just be a pirated, out of date, version of the his (PGPSW) cameras!
Are you saying that POI-Handler's POIs DO actually get displayed on the map display itself rather than just separately on the left of the screen? That could be quite interesting.
dougproctor
PostPosted: Sun May 24, 2009 9:00 pm    Post subject: Reply with quote
Hi again
Didn't pay anything for it! put some more sounds on there tonight so will give that a go tomorrow.
When you say appear on the map, I have lots of icons but whether they are poi-handler's or PGPSW's as I have a mixture of both.
Doug
jainpankaj
PostPosted: Wed May 27, 2009 1:14 pm    Post subject: Reply with quote
dougproctor wrote:
Hi David,
Strange. Put the cameras from here in there and now have overlays available 120, POI monitored 1438 and POI displayed 16.385 with green ticks against all three boxes.
I think the POI monitored are the PGPSW cameras and the POI's from POI-Handler are still not being monitored.
Any ideas please?
Doug
Doug what did you do to get the POI Monitored from 0 to 1438. As on mine POI Displayed is 59935 but POI Monitored is 0.
Please help
Pankaj
dougproctor
PostPosted: Wed May 27, 2009 2:06 pm    Post subject: Reply with quote
If you go to the main POI Warner screen, stop the monitoring and then click POI-Manager-POI settings-Overlay settings. Then select all or whatever POi's you want monitored. Click okay etc to get back to the main POI-Warner screen. Do a soft reset by putting a small needle in the hole on the bottom on the unit.
When you start up again, start the monitoring again and, hopefully, your POI count should have gone up.
As I am at work without my unit, I am trying to visualise the steps so give that a try first. Good luck.
Doug
jainpankaj
PostPosted: Wed May 27, 2009 2:22 pm    Post subject: Reply with quote
Thanks a lot for the quick response.
Much appreciated.
I have done this many times all my POI are ticked for monitering and I have done the soft reset many times but the count seems to be 0.
I could not manage to perform automatic sync using Navigon Fresh. It keeps storing the bmp files without the asc files. With this I was always getting both the POI Displayed and POI Mointored counts 0.
I then went to www.poihandler.com and downloaded all the .bmp and .asc files manually and save them under POIWarner\pois. Once this was done and I did a soft reboot by pressing the reset button, I get non zero counts for overlays and POI Displayed but POI Monitor is still 0.
Is there any thing wronfg with the asc files downloaded from poihandler.
dougproctor
PostPosted: Wed May 27, 2009 3:44 pm    Post subject: Reply with quote
Hi again,
Strange. I use a combination of POI's from POI-Handler and from Pocketgpsworld. The latter need converting from csv to asc files using POI-Edit but they install just fine. When you soft reset your unit after putting the POI's on there, do you get a small box that tells you the files are being converted to POI format? Each POI in done, one after the other. If you are not getting this, perhaps this is the problem. Have you tried deleting the POI's from POI-Warner and then reinstalling them? I thought that Navigon Fresh was for loading maps etc, I use another program for synching. That program is installed with Navigon Fresh. I will have a look when I get home and see if any other settings have to be done. If I remember rightly, I think there is another setting that needs tick boxes but I may be wrong!
Will be back on later with any other info I find.
Doug
jainpankaj
PostPosted: Wed May 27, 2009 4:31 pm    Post subject: Reply with quote
I do get this dialog, which says converting POI. But I have been using POI files from www.poihandler.com. May be I should try POI files from PocketPGS.
How do you delete POI from Navigon? And how do you convert .csv to .asc. I guess you need to keep POI files into the POINWarner\pois folders.
Page 3 of 6
22.063 (19 Jun 24)
