Pocket GPS World :: View topic - tom tom go 520....HELP
ANDYSUDS
PostPosted: Thu May 21, 2009 6:55 pm    Post subject: tom tom go 520....HELP Reply with quote
Help,somehow i have managed to delete the maps from the device,when i open in tt home no maps are there,have no back up,can and how am i able to download the uk & ire map from anywhere or any other hints.. Crying or Very sad
PostPosted: Thu May 21, 2009 7:02 pm    Post subject: Reply with quote
If you have no backup then you will have to purchase a new map from TomTom using the TomTom Home software on your PC, there are no alternate outlets for the maps these days - Mike
ANDYSUDS
PostPosted: Thu May 21, 2009 7:04 pm    Post subject: Reply with quote
will the maps still be on the pc ,if so what is the file called,excuse the daft questions i am a novice
dhn
If your maps were, at one point, updates from what map originally came on your unit, then they may still be found on your computer in the TomTom/download/map folder.
Good luck....
ANDYSUDS
PostPosted: Thu May 21, 2009 7:11 pm    Post subject: Reply with quote
i have a folder with 3 files in it
1=8.350.gox20.cab-navcore-go.......39,485kb
2=8 toc.....3kb
3=png image......
is this what i am looking for
PostPosted: Thu May 21, 2009 7:20 pm    Post subject: Reply with quote
Did you ever download an updated map for your device? if not there won't be a file on the PC, if you did download a map update try searching the PC for United_Kingdom_and_Republic_of_Ireland as that is what the file will be called while still zipped up its around 185MB in size - Mike
ANDYSUDS
PostPosted: Thu May 21, 2009 10:52 pm    Post subject: Reply with quote
would i be able to buy a card with the map o,n and if so can anybody give me some stores to try,i am not to confident about downloading a map and installing it,if i can get a card pre installed is it just a matter of putting it in and turning the machine on and away you go,sounds easy,
BrianCollison
PostPosted: Fri May 22, 2009 2:45 am    Post subject: Maps preloaded on sd card Reply with quote
I have just purchased maps pre-installed on an sd card, which seems to work fine, from a company called Hyper Gear for £44 including postage. everything you need is installed on the card. the only thing is if you make another backup on another sd card it may not work, I tried it and it didn't work for me but the original does. I found this company on Amazon.
PaulB2005
PostPosted: Fri May 22, 2009 9:28 am    Post subject: Reply with quote
Brian
Can you confirm what map version you got?
Can you link to the store as i can't find it?
BrianCollison
PostPosted: Fri May 22, 2009 10:47 am    Post subject: Maps preloaded on sd card Reply with quote
PaulB2005 wrote:
Brian
It is the latest maps and applications version 8.350
Found on Amazon under TomTom maps
iainkirk
PostPosted: Fri May 22, 2009 11:29 am    Post subject: Reply with quote
PaulB2005 wrote:
Brian
It's here:
http://www.amazon.co.uk/gp/offer-listing/B001N7E0M8?ie=UTF8&ref%5F=dp%5Folp%5F0&qid=1242988089&sr=8-2&condition=all
