Pocket GPS World :: View topic - TECH: faulty RDS/TMC socket?
erikthecat
PostPosted: Fri May 15, 2009 12:44 pm    Post subject: TECH: faulty RDS/TMC socket? Reply with quote
oops posted this in the wrong area the other day! :(
this old chestnut again, but i believe it to be hardware related this time, socket to be more precise.
it was working, then it was intermittent, then it wasn't.
it would search for a signal, then say it wasn't available.
i have the replacement rdstmc module.
i've jumped through all the tom tom tech support hoops, i must have tried all software from 7481 to 8301, but still no joy.
if i send it back how much am i looking at, as both the sat nav / tmc module are over a year old!
they aren't going to fix this for free are they?! :)
could i open the thing up and bent the contacts?
i have a feeling that's what it is, all that plugging and unplugging:(
are there any continuity check that i could make before doing that any of that? and will i actually be able ti get the thing back together if i take it apart? :)
many thanks for your time.
GaRy:)
Tom Tom 720
8.1 rds-tmc seems to be broken?
home 2.5
map we 710.1561
rds-tmc v4.00.013 (replacement)
PostPosted: Fri May 15, 2009 1:00 pm    Post subject: Reply with quote
Send it back, chances are they'll repair it FOC anyway as it's a known issue and I think the warranty is 2yrs as well?
Or buy the newer mini-USB TMC antenna instead.
erikthecat
PostPosted: Fri May 15, 2009 2:20 pm    Post subject: mini-USB TMC antenna Reply with quote
thanks for the reply,
would you have a link to said "mini-USB TMC antenna"
the power is currently supplied to the existing mini usb socket on the base of the 720, how does the new device connect in?
regards,
GaRy
Tom Tom 720
home 2.5
map we 710.1561
MrT
PostPosted: Fri May 15, 2009 2:30 pm    Post subject: Reply with quote
Power goes into TMC device USB socket then TMC-USB plug goes into device.
Drivelux
PostPosted: Fri May 15, 2009 3:28 pm    Post subject: Re: mini-USB TMC antenna Reply with quote
As MrT has said, it plugs into your device via Mini-USB and then your charger plugs into the TMC receiver.
The product can be found on TomTom's site here.
trooper
PostPosted: Wed May 27, 2009 8:56 pm    Post subject: Reply with quote
I have a similar problem, the black 'O' ring is missing from my 930 after about 6 months of use. I could send it in for repair, but am I right in assuming the USB version would still work.
I gather this is a known problem and obviously a weak point not suitable for being plugged in and out all the time. The USB port would appear to be much more robust.
Any comments?
Ian
PostPosted: Wed May 27, 2009 9:56 pm    Post subject: Reply with quote
You will be fine using the mini USB receiver even with a broken iPOD/ RDS socket, although if you ever think you might want to connect an iPOD to the device then consider getting it fixed - Mike
trooper
PostPosted: Wed May 27, 2009 10:04 pm    Post subject: Reply with quote
Thanks Mike
Calomax
PostPosted: Thu May 28, 2009 9:25 am    Post subject: Reply with quote
The product can be found on TomTom's site Here at Amazon for £22.99
Sorry, I've lost my instructions how to put a link in properly. Are they anywhere on the forum please?
Edit to answer issue about the link, (try hitting the edit button to see what I have done to the text) - Mike Alder
TT Go Essential
23.012 (08 Jan 25)
