Pocket GPS World :: View topic - One XL. Totally Confused!!!
chelsky
PostPosted: Thu May 14, 2009 5:40 pm    Post subject: One XL. Totally Confused!!! Reply with quote
HI. Following on from a previous thread, I have another question.
My m8 decided to upgrade his map. He paid £60 for the Western European upgrade from v675.1409 too 825.2159. After it crashed!! once, on his very slow computer, I brought it home, and using his log on details, I downloaded it again and everything went smoothly!!! Now, when I tap the screen on the right hand side, it is still showing v675.1409 for the map!! He has an "Integral 2Gb" card which my computers card reader wont read. TT Home tells me that this upgrade is on the TT. Any help would be really appreciated.
chelsky.
PS. I am about to try to install the upgrade without the card.
PostPosted: Thu May 14, 2009 6:49 pm    Post subject: Reply with quote
It may be that the map was installed to the internal memory? Does the unit boot without the SD card installed? If so what does it report in this case?
chelsky
PostPosted: Thu May 14, 2009 6:58 pm    Post subject: Reply with quote
Hi Darren. It boots without the card and as was. With the card same same.
chelsky
PostPosted: Thu May 14, 2009 7:01 pm    Post subject: Reply with quote
Do you mean it reports the same v6 map version when booting without the card?
The other thing to check is the Manage Maps option in Change Preferences. Are you given a choice of maps to switch between? When connected to the computer, do you see two Western_Europe (or similar named) folders on the device?
chelsky
PostPosted: Thu May 14, 2009 7:33 pm    Post subject: Reply with quote
I will check Darren
chelsky
PostPosted: Thu May 14, 2009 7:41 pm    Post subject: Reply with quote
Checked, and only one choice in manage maps and one Western European folder
PostPosted: Thu May 14, 2009 7:45 pm    Post subject: Reply with quote
And what about when the SD card is inserted?
PostPosted: Thu May 14, 2009 7:57 pm    Post subject: Reply with quote
Deleted
Now realise model number is in the title only.
PostPosted: Thu May 14, 2009 7:59 pm    Post subject: Reply with quote
Was there more than one ONE XL model that came with an SD Card slot?
PostPosted: Thu May 14, 2009 8:00 pm    Post subject: Reply with quote
Nah.. ignore me. I'd read the post and there was no model mentioned at all. It was only in the title... Embarassed
chelsky
PostPosted: Thu May 14, 2009 8:10 pm    Post subject: Reply with quote
Hi Darren. Inserted the sd card and have two choices. Western Europe and Western Europe 1GB on the machine and also when viewed in explorer
PostPosted: Thu May 14, 2009 8:13 pm    Post subject: Reply with quote
Ah so there is your answer. Your mate has purchased a slightly different version of the map and so HOME has installed it as another map rather than overwrite the existing one.
If you switch to the one that is not currently loaded you should find it is the later map version.
chelsky
PostPosted: Thu May 14, 2009 8:25 pm    Post subject: Reply with quote
The new map, offered by home by the way, is the new version 825.2159.
Can I delete the older map or leave it alone and leave the new one selected. Thanks
PostPosted: Thu May 14, 2009 8:33 pm    Post subject: Reply with quote
Entirely up to you. If you do choose to delete it, take a copy and keep on your PC just in case before deleting via HOME.
chelsky
PostPosted: Thu May 14, 2009 8:47 pm    Post subject: Reply with quote
Thanks for all your help Darren, really is appreciated. What I will do is make a backup with the sd card in and make a backup of Western Europe in a separate folder. All with Explorer of course Laughing
22.064 (26 Jun 24)
