Andy_P Pocket GPS Moderator
Posted: Tue May 12, 2009 1:36 pm Post subject: |
spannersatcx wrote: | Quote: | Even if the volume is slightly lower (I'm not convinced of that, yet) | You're not convinced of what, that the volume is lower ors slightly lower (in that how can people tell) I can assure you that it is significantly lower so much so with a radio on at a modeate level and normal road noise you CAN NOT hear spoken instructions on my 520 that was fine before. ![Mad](modules/Forums/images/smiles/icon_mad.gif) |
Yes I realise what you're saying but I can assure you that is NOT the case on any of my three updated units. So it ain't simple.... |
wigfield Regular Visitor
![](modules/Forums/images/avatars/gallery/wings2.jpg)
Posted: Tue May 12, 2009 2:13 pm Post subject: |
Well ive done a test of my own
With the new navcore:
Tested in car:100% volume if i want to hear it while ive got the radio on anything below is useless
In a van 100% volume can only just hear it on 100% without radio.
Back to the last navcore 80% volume in Car/Van with radio on |
jimbo_hippo Frequent Visitor
![](modules/Forums/images/avatars/21077135774339845938047.gif)
Posted: Tue May 12, 2009 2:20 pm Post subject: |
Has anyone done any tests on whether earlier tweaking done with voice files from previous releses/fixes from here have any bearing on this? I can't for the life of me remember what I did when trying to fix the stutter but I'm sure there was some voice file swapping going on wasn't there? I might try deleting voices and redownload to see if that fixes it. Would explain the random nature of this issue. Anyone tried that? _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
paynee2k Occasional Visitor
Posted: Tue May 12, 2009 3:00 pm Post subject: |
I can confirm that the volume on my 520 is now significantly lower.
I updated to the latest release last week and realised there was a volume problem. I switched maps from the SD to the one on the HD and it was back to normal but upon further investigation i found that only my SD card had updated to the latest version and not the tomtom itself. I then updated the tomtom with the latest version and now have the same low volume problem.
"Link volume to noise level" option unticked
Conclusive evidence that there is a problem. |
Posted: Tue May 12, 2009 3:23 pm Post subject: |
OK, decided to just try it. Connected to Home, deleted Kate and the bloke computer voices electing not to save a backup. Then downloaded replacement via home, still the same. _________________ Tom Tom GO 720
Holux GPSslim |
richard345 Frequent Visitor
![](modules/Forums/images/avatars/163426356250c51a2a2eb8f.jpg)
Joined: Mar 09, 2008 Posts: 463 Location: Rainhill, Lancashire Not Merseyside!
Posted: Tue May 12, 2009 3:29 pm Post subject: |
paynee2k wrote: | I can confirm that the volume on my 520 is now significantly lower.
I'm now of a different opinion. I updated the system on the SD card of my 520 and had, like you the low volume issue. The Internal Memory has Navcore 7.221 and Map 715 on it and when I booted from that, I had 'normal' volume levels.
Backed up both the Internal Memory and SD Card to my pc and installed a backup copy of 8.302 & Map 815 to the Internal Memory - correct volume.
I then allowed HOME to update the Internal memory and the volume levels are unchanged. Finally, I backed up the Internal Memory, deleted everything and restored the backup of 7.221/715 to it and then wiped the SD card and copied the updated internal memory backup to the card.
I can now boot on either and the volume is exactly as before the upgrade and Kate at 30% - 40% in my Astra is just fine.
I know it's a bit of a faff, but it worked for me. YMMV. _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course!
mightyyid Pocket GPS Verifier
![](modules/Forums/images/avatars/6268972144a2742484df16.jpg)
Joined: Apr 04, 2006 Posts: 83 Location: Melbourne, Australia
Posted: Tue May 12, 2009 3:47 pm Post subject: |
Thanks Ric - but what are you saying? That volume levels are fine on yours but are you running 8.350 - the latest, or just the previous version, since it does seem you are not running 8.350 thus should not have the issue. Or have I missed something? |
reapeer Occasional Visitor
Posted: Tue May 12, 2009 4:11 pm Post subject: |
Matt865 wrote: | This release seems to have fixed the 31mph bug.
Now that I have a satellite lock it my device tells me I am doing 0/30 mph instead of 0/31mph.
edit: like some other new navcores, when you browse the map it shows you a floating arrow tip that shows the distance to home/ destination, plus an arrow showing North in relation to the direction you should be heading.
edit2: operate my Go is working right off the bat too.
![](http://i44.tinypic.com/2j2u4hz.jpg) |
which model tom tom do you have my 920 has updated ok no problems with the sound or with kates voice but i dont have the icons you have when i browse the maps
i want them and i want them now !!!!!!!!!!!!!!!!!!!!!!!!!!! ![Laughing Out Loud](modules/Forums/images/smiles/icon_lol.gif) |
Posted: Tue May 12, 2009 4:38 pm Post subject: |
Zoom in then scroll the map so your Home, destination and current position are no longer on the display, as soon as these loactions go off map the pointer appear to show you where they are relative to your display.
If this still doesn't work try Browse Map/ Options/ Advanced and make sure "Markers" is selected - Mike |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Tue May 12, 2009 5:45 pm Post subject: |
very happy with my 720 right now ,the voice is a bit lower but I can still hear with the radio on and I have ear problems and can't hear a thing , see they fixed the delete poi acceptance and like all the minor changes they have made ..I think the car symbol has been changed slightly as my stealth now has a fine red line around it and I'm sure there never was a shadow beneath it too ....thing is I still seem to be getting to my destination fine so no problem there _________________ TomTom 5001 |
Posted: Tue May 12, 2009 6:40 pm Post subject: |
mightyyid wrote: | Thanks Ric - but what are you saying? That volume levels are fine on yours but are you running 8.350 - the latest, or just the previous version, since it does seem you are not running 8.350 thus should not have the issue. Or have I missed something? |
Sorry for being unclear. Both application versions are working fine now. Kate on 30-40% volume on 8.35 is more than loud enough in my Astra. _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course! |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Posted: Tue May 12, 2009 6:42 pm Post subject: |
richard345 wrote Quote: | volume levels are uncganhed | ![Question](modules/Forums/images/smiles/icon_question.gif) _________________ TT Go Essential |
Posted: Tue May 12, 2009 6:49 pm Post subject: |
Calomax wrote: | richard345 wrote Quote: | volume levels are uncganhed | ![Question](modules/Forums/images/smiles/icon_question.gif) |
Original edited to read 'unchanged'
Dyslexic fingers and a Senior Moment - got my bus pass last weekend. ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course! |
Posted: Tue May 12, 2009 7:17 pm Post subject: |
mikealder wrote: | Zoom in then scroll the map so your Home, destination and current position are no longer on the display, as soon as these loactions go off map the pointer appear to show you where they are relative to your display.
once again ya come up with the good
it was ticked but i never wandered off the map before far enough so now they appear i think they are usefull but then i am a gadgit man
just one small point for those who have trouble with voices my voices are not in tom tom itself they are on a sd card when i first had problems with Kates voice she would start to givve instructions then break up support tried everything to fix it, then i got an SD card changed devices in tom tom home and did an update my device all the voices came down for update to the card along with maps and application so i put the voices only on the card because of its size and all is well dont know if anyone else has tried this but its worth a go
cheers mike ![Razz](modules/Forums/images/smiles/icon_razz.gif) |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Posted: Tue May 12, 2009 8:10 pm Post subject: |
I am not sure about the markers, if I am at home, the distance to GPS marker and the distance to Home marker can show very different figures when I would have expected them to be the same. _________________ Drivelux |
