reapeer Occasional Visitor
Posted: Fri May 08, 2009 10:42 am Post subject: |
PaulB2005 wrote: | What model do you have? This update is for x20, x30 and x40 models.
It been offered on TT Home for my 740.
Check again today shows I am still being offered the update. |
i have the 920T but i cant download application updates some times for some reason mine only wants to d/load the 7xxxx if i deleat the 83xxx i only get the 7xxxx application offered, and i have had every concievable thing tried on mine by the tech people to get it also the teh voices were broken up but i put a card in mine and added the voices to that and tehy work fine now |
Posted: Fri May 08, 2009 10:50 am Post subject: |
If you take a look at This post (from the previous page) it contains links for direct download of the Navcore 8,350 try using that, if you don't know how to install it post back but download and install WinRar to your PC first - Mike |
does anyone have a direct link to teh new update i would like to see what happens on mine i have all my backups so it shouldnt be a problem to restore it back if it up |
Posted: Fri May 08, 2009 11:12 am Post subject: |
mikealder wrote: | If you take a look at This post (from the previous page) it contains links for direct download of the Navcore 8,350 try using that, if you don't know how to install it post back but download and install WinRar to your PC first - Mike |
sorry mike but i just checked that page its for the 802 version both of the d/loads not the 850 |
shuttle1981 Lifetime Member
Posted: Fri May 08, 2009 11:22 am Post subject: |
Dear PGPSW
Can you please advise your membership to NOT download the latest application 8.350 software as there is a major bug which reduces the spoken volume down by at least 50 %.
So at normal road noise level the device is difficult to hear when the unit is on 100% volume.
Why TomTom cannot get there software to work is beyond me, there is a perfectly good volume bar at the bottom of the touch screen to reduce the volume if required.
Many thanks
Clive Watson
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Fri May 08, 2009 11:23 am Post subject: |
I always follow the excellent advice offered by Mike Alder some time ago, and put any new application on SD card, leaving the old app on the device. That way I'm able to remove the card and revert to the old app if I have problems.
I've now downloaded the new app to internal memory, as I experienced none of the problems reported here - so far!
Sorry, DennisN, but the volume seems exactly as it was before. Could that be because I reverted to the official software and voices before downloading the last map update? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Fri May 08, 2009 11:30 am Post subject: Re: TomTom release v8.350 for GO x20, GO x30 and GO x40 |
Jackaws wrote: | Hi Darren,
I've connected to TTHome and run 'update my device'. It has downloaded map share and GPS fix information but has not offered me the 8.350 update. Am I missing something?
This is not the first time that I appear to be 'last in the queue'.
I have tried reconnecting and updating. No joy.
Any suggestions? |
join the queue im the same |
Posted: Fri May 08, 2009 11:40 am Post subject: |
reapeer wrote: | sorry mike but i just checked that page its for the 802 version both of the d/loads not the 850 |
Sorry thats my mistake, I should have read the details rather make assumptions, I think the following is what you want:
Go-x20 Navcore 8,350
Go-x30 Navcore 8,350
Hope that helps - Mike |
bendyfurd Occasional Visitor
Posted: Fri May 08, 2009 11:49 am Post subject: v8.350 Upgrade |
Can anyone tell me why my TT Home (on Mac) won't offer me the new v8.350 update? I connected today & was offered the usual Quickfix sat location but nothing else. I have a TT Go 720, thanx. |
richard345 Frequent Visitor
Joined: Mar 09, 2008 Posts: 463 Location: Rainhill, Lancashire Not Merseyside!
Posted: Fri May 08, 2009 12:15 pm Post subject: |
OK, I deleted the whole of my SD Card and restored a good working version of 8.302 to the Internal Memory of my 520.
Everything was fine. Connected to the pc and started HOME. I was immediately offered the 8.35 upgrade and so let it go ahead. On completion, the 520 was restarted and a QuickGPSFix file offered. Again, I allowed that to download and install.
Disconnected from the pc by using the icon in the bottom right of the HOME Screen and the 520 booted up on the Internal Memory without any issues at all. I got a GPS Fix in the house, where with the earlier attempt at upgrading had failed.
Kate and Simon worked fine and the route planner was back to the 8.302 speed.
Connected up to the pc again, started HOME and went to Operate My Go. Straight away, I was told an additional file was needed and so I requested it. During the download, my broadband stuttered, so the download was incomplete. Closed HOME, opened it again and went again to Operate My Go. File was offered again and this time it came down OK and installed. Operate My Go is now working fully.
I then moved all the contents of the Internal Memory to the blank SD Card and restored the old 725/710 version I had to the Internal Memory and now both versions work fine.
New full Windows backups have been taken of the device as it stands, so I'm happy.
On the short trip to work this morning, all I had to do was turn the volume of Kate's instructions DOWN to 30% and change the car icon to my own Astra one which was kindly provided for me here.
OK, I need to restore some more of the preferences, but that's no problem.
Conclusions and advice if you have issues - don't panic, clear the version you downloaded earlier and try again. It works for me.
Thanks to everyone here who has posted their experiences and I hope we will all soon be at a stable operating level ready for the Map Upgrades, which should not be too far away. _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course! |
peasemore Lifetime Member
Posted: Fri May 08, 2009 12:29 pm Post subject: Re: Update screwed my TMC (720T) |
peasemore wrote: | I have used today, and all seems fine save for the TMC
which now does not appear at all, where it always used to. |
Anyone else experiencing this??? _________________ Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve. |
jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Fri May 08, 2009 12:31 pm Post subject: |
Ric
That is exactly what I did and as far as I can tell the upgrade is working well.
The only thing that I had to change was the closing down picture which had been changed by the upgrade to the standard tomtom one. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
Posted: Fri May 08, 2009 1:03 pm Post subject: |
mikealder wrote: | reapeer wrote: | sorry mike but i just checked that page its for the 802 version both of the d/loads not the 850 |
thanks mike works perfectly |
carl_the_cobbler Frequent Visitor
Posted: Fri May 08, 2009 1:45 pm Post subject: |
Hello,
Just put on new 8.350 and my 3 mobile TyTn II works perfectly now, Hurrah!!! All the other bits seem nice as well!! |
Posted: Fri May 08, 2009 2:10 pm Post subject: |
Makes you wonder if the number of people trying to get the download yesterday has had an effect of a file within it that has been corrected overnight.
It may just have been on one of the servers that one connects to out of the several that they have (I think)
8.350 still working OK after going out at lunch time. 30% volume is more than enough for me. _________________ Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course! |
