Pocket GPS World :: View topic - fm tranmitting without music
NO_MAD
PostPosted: Thu May 07, 2009 5:09 pm    Post subject: fm tranmitting without music Reply with quote
Hi all
Can I get my 720 to think that is playing music and still get the fm transmitter to transmit without music playing?
NO_MAD
dhn
PostPosted: Thu May 07, 2009 5:47 pm    Post subject: Reply with quote
I believe a solution is to create a 30 second mp3 file which is completely silent and set it to play repeatedly in jukebox.
In fact, I wonder whether the mods can create the file (Andy_P ?? Laughing ) and attach it to a message here for others to dl and implement.
PostPosted: Thu May 07, 2009 6:08 pm    Post subject: Reply with quote
Your wish is my command... Laughing
Silence is Golden.mp3 (right click and "save as...")
Edit: Original 30 sec 44.1 stereo file replaced with 5 minute 22.05 Mono file - should make no practical difference, but means the TT will have to work less hard looping it continuously.
dhn
PostPosted: Thu May 07, 2009 6:33 pm    Post subject: Reply with quote
Thank you, Andy........
Gosh, it's fun to make work for others .......... Razz
NO_MAD
PostPosted: Thu May 07, 2009 9:37 pm    Post subject: Reply with quote
Thank you Andy_p for Silence is golden
I have copied silence is golden on to a SD card.
How do I get my 720 to play this file?
Do i have to put this file in a folder?
Regards
NO_MAD
wigfield
PostPosted: Thu May 07, 2009 10:01 pm    Post subject: Reply with quote
So are you saying if you dont have music playing after so many minutes the transmitter stops working?
mz500r
PostPosted: Thu May 07, 2009 10:04 pm    Post subject: Reply with quote
Regards
NO_MAD
hi yes it has to be in a folder named mp3 hth
TomTom 530 App 8.351 UK map v8.50.2781
TomTom rider 2 App 7.901 U.K. v850.
AliOnHols
PostPosted: Thu May 07, 2009 10:16 pm    Post subject: Reply with quote
Many thanks NO_MAD for bringing this excellent TopTip to our attention and to dhn and Andy_P for making it happen.
Regards, AliOnHols.
Garmin Nuvi 2599
SatMap Active 10 & 20.
NO_MAD
PostPosted: Thu May 07, 2009 10:37 pm    Post subject: Reply with quote
I have put it in a folder called mp3 hth on the sd card.
But sill can not get it to open on my 720.
NO_MAD
mz500r
PostPosted: Thu May 07, 2009 10:44 pm    Post subject: Reply with quote
NO_MAD
sorry mad mp3 (hth =hope this helps) Embarassed
mz500r
PostPosted: Thu May 07, 2009 10:45 pm    Post subject: Reply with quote
dhn
PostPosted: Thu May 07, 2009 10:48 pm    Post subject: Reply with quote
Put it in a folder called mp3. There is no hth involved. Make sure the folder name is all lower case.
AliOnHols
PostPosted: Thu May 07, 2009 11:10 pm    Post subject: Reply with quote
NO_MAD, my mp3 folder is is on my internal Root memory and works as it should. You can also put the mp3 folder on your SD card and your 720 should detect this also.
Just to confirm :-
Create a FOLDER called mp3. Place it onto either your SD card or INTERNAL root memory.
Drag and Drop "Silence is Golden. mp3" into folder mp3.
Select "Silence Is Golden" from - Music & Media - TomTom Player. on the TT menu options. Set it to repeat.
You should now be listening to Nothing!
Garmin Nuvi 2599
PostPosted: Thu May 07, 2009 11:31 pm    Post subject: Reply with quote
Just a reminder, this will only work with v8.350 software and ONLY on the x20 and x30 models (the ones that originally could put nav instructions on FM).
Unfortunately TT have not enabled it on the 940 as that has never been able to do it in the past. Hopefully they will soon!
NO_MAD
Hi All
Have put silence is golden into my mp3 folder on the root dir,
Selected it .Now woking with out a sd card Very Happy
Thankyou all for your help
NO_MAD
23.012 (08 Jan 25)
