Pocket GPS World :: View topic - Can I remove transferred routes from My Data
Meter_Man
PostPosted: Mon May 04, 2009 11:47 pm    Post subject: Can I remove transferred routes from My Data Reply with quote
Was trying to copy routes from Mapsource to my Nuvi 760 and tried several times before I found on here that routes transfer to My data where you can import them to the routes folder. However, I now have two or three copies of each transferred file in My Data - is it possible to delete these once you have imported the routes?
Have searched the forum without success!
Peter Confused
PaulB2005
PostPosted: Tue May 05, 2009 7:52 am    Post subject: Reply with quote
It is silly you can't delete these easily from the unit.
Connect the Nuvi to your PC. Look on the Nuvi memory for a folder called Garmin/GPX. Look for a file in there called TEMP.GPX. Delete it. That should do it.. It will delete all the but then just import the ones you do want.
You could try EasyGPS to see it it'll open that file and allow you do selectively delete routes. I've not tried this myself.
Meter_Man
PostPosted: Tue May 05, 2009 9:59 pm    Post subject: Reply with quote
Thanks Paul, it did the trick, removed all the duplicates and just left the ones I wanted.
Peter
22.064 (26 Jun 24)
