Pocket GPS World :: View topic - TOm tom Go Traffice Preferences
sja0001
PostPosted: Sun May 03, 2009 9:38 pm    Post subject: TOm tom Go Traffice Preferences Reply with quote
does anyone know if you can change the pre-set road speeds on the above? Mine is forever taking me along minor B roads when there's a dual carriage A road next to it - but 100 yards longer (over 5 miles or so!)
thanks
SJA0001
PostPosted: Sun May 03, 2009 10:16 pm    Post subject: Reply with quote
This isn't possible to do, but if you know better than the device due to local knowledge simply ignore the device, it will soon work out where you are going - Mike
sja0001
PostPosted: Mon May 04, 2009 10:09 am    Post subject: Reply with quote
Thanks Mike, if it was local I'd ignore but usually use it to find NT properties etc.
Oh well , have to see what els I can do
thanks
PostPosted: Mon May 04, 2009 10:16 am    Post subject: Reply with quote
As you have a 530 which should be running the v825 maps (the current latest released) the device should use the IQ-II Routes data from the map to work out the best route dependent upon actual known road speeds that people have driven.
Assuming you don't have IQ Routes turned off the device should use the IQ data - Mike
sja0001
PostPosted: Wed May 06, 2009 9:27 pm    Post subject: Reply with quote
Thanks again Mike, I'll check the settings as amazed if the B roads it kept suggesting were as fast/faster.
Steve
Calomax
PostPosted: Thu May 07, 2009 8:51 am    Post subject: Reply with quote
I presume you are using fastest route not shortest route when you are planning.
TT Go Essential
sja0001
PostPosted: Sat May 09, 2009 8:47 am    Post subject: Reply with quote
Yes - fastest route selected
thanks
22.063 (19 Jun 24)
