sja0001 Occasional Visitor
Posted: Sun May 03, 2009 9:38 pm Post subject: TOm tom Go Traffice Preferences |
does anyone know if you can change the pre-set road speeds on the above? Mine is forever taking me along minor B roads when there's a dual carriage A road next to it - but 100 yards longer (over 5 miles or so!)
thanks
SJA0001 |
Posted: Sun May 03, 2009 10:16 pm Post subject: |
This isn't possible to do, but if you know better than the device due to local knowledge simply ignore the device, it will soon work out where you are going - Mike |
Posted: Mon May 04, 2009 10:09 am Post subject: |
Thanks Mike, if it was local I'd ignore but usually use it to find NT properties etc.
Oh well , have to see what els I can do
thanks |
Posted: Mon May 04, 2009 10:16 am Post subject: |
As you have a 530 which should be running the v825 maps (the current latest released) the device should use the IQ-II Routes data from the map to work out the best route dependent upon actual known road speeds that people have driven.
Assuming you don't have IQ Routes turned off the device should use the IQ data - Mike |
Posted: Wed May 06, 2009 9:27 pm Post subject: |
Thanks again Mike, I'll check the settings as amazed if the B roads it kept suggesting were as fast/faster.
Steve |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Posted: Thu May 07, 2009 8:51 am Post subject: |
I presume you are using fastest route not shortest route when you are planning. _________________ TT Go Essential |
Posted: Sat May 09, 2009 8:47 am Post subject: |
Yes - fastest route selected
thanks |
