exgerminater Occasional Visitor
Posted: Thu Apr 30, 2009 8:10 am Post subject: Nissan connect |
I have changed my car, I now have a Nissan Note with the connect satnav system
does anyone know which speed camera file ( if any ) is compatable with this system? The system booklet states the file must be .csv format.
Thanks |
Posted: Thu Apr 30, 2009 8:21 am Post subject: |
HI and welcome.
You could try the download or the format.
Do you know what software the sat nav runs? |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Thu Apr 30, 2009 8:29 am Post subject: Re: Nissan connect |
Hi exgerminater,
to the forum!
exgerminater wrote: | The system booklet states the file must be .csv format. |
That's encouraging! Does the system booklet state:
1. How you load the .csv file?
2. Do you use a single .csv or multiple .csv files?
3. Do you have to load any icon files for the screen (i.e. .bmp files)
Do you have a link to the on-line manual for your Sat Nav?
The PocketGPSWorld camera database can be downloaded in .csv format so once we know what your unit expects, then you should be able to use the PGPSW camera database on your unit.
Edit: Beaten by PaulB2005 again!
Garmin Camper 770 LMT-D |
Posted: Thu Apr 30, 2009 8:32 am Post subject: |
From what i can find
Quote: | Routes to the intended destination can be calculated as fastest, shortest and for the first time “Eco”: which optimises the route for good fuel economy. |
Quote: | In addition to the installed Points of Interest, updates to the system’s Points of Interest database can be made using the USB port. This type of information includes hotels, service stations and restaurants, among others.
Additionally, the location of safety camera locations can be uploaded via the USB port, while map updates can be purchased and easily loaded into Nissan Connect using an SD data card slot on the front of the panel. |
CSV and Eco mode? I wonder if it's Garmin based? |
Darren Frequent Visitor
Posted: Thu Apr 30, 2009 9:12 am Post subject: |
We've been trying to assist another member via email on this and so far have not succeeded. Even Nissan don't appear to have any details of the exact .csv format it needs and none of the ones we have tried have worked. _________________ Darren Griffin |
Andy_P Pocket GPS Moderator
Posted: Thu Apr 30, 2009 11:41 am Post subject: |
PaulB2005 wrote: | From what i can find
Sorry... OT, but can anyone read the word after "first time" in that quote. On Firefox3 it's complete gibberish, which seems to be happening a lot with the new version. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15148 Location: Bradford, West Yorkshire
Posted: Thu Apr 30, 2009 11:55 am Post subject: |
Andy_P wrote: | PaulB2005 wrote: | From what i can find
yes and no! “Eco” is 'Eco' BUT instead of standard quote marks it's using those annoying ones that Word uses that curve depending on whether it is the opening or closing quote. my guess is that paul copied and pasted from another document!
MaFt |
Posted: Thu Apr 30, 2009 5:50 pm Post subject: |
Sorry missed that!!! It was copied and pasted from a review. It was pain text in the review so not sure why it came out like that here! |
Posted: Thu Apr 30, 2009 9:18 pm Post subject: Nissan Connect Sat Nav |
Thanks for all the help & suggestions offered, I will try out some of the ideas and send some feedback
Thanks again |
thomas04 Occasional Visitor
Posted: Fri May 01, 2009 10:25 am Post subject: Nissan satnav |
I have loaded the garmin csv files into my nissan sat nav via the usb port. The satnav recognised them 1st time. |
suzukiscottie Occasional Visitor
Posted: Wed May 27, 2009 4:22 pm Post subject: Nissan Connect |
Your own POI's need to be loaded onto a USB stick in a folder called "myPOIs". They need to be in CSV format. Long; Lat and then Identifier.
If you have POIs which you would like to have a warning displayed/sounded (i.e. cameras etc), then those POI files need to be dropped onto the USB stick into a folder called "myPOIWarnings". Same CSV format as above.
As soon as you plug the stick into the cars USB port, a window pops up on the screen saying "new POIS available". Select the "download" option on the touchscreen and about a second later the job is done! :-)
In the navigation setup pages, you may wish to modify your POI warning distance. It is set at 250 yards by default. |
Posted: Wed May 27, 2009 5:30 pm Post subject: |
Excellent news, thanks for taking the time to post the install details. I'm compiling a guide and will update our compatibility table but can you confirm which database format you used and which type i.e. will it only function with single-file or does it work with the others? _________________ Darren Griffin |
Posted: Wed May 27, 2009 5:52 pm Post subject: |
and does it use the bitmaps or it's own images? |
stiman Occasional Visitor
Posted: Thu Jun 11, 2009 10:12 pm Post subject: |
Hello all, I have the Nissan Qashqai +2, with Nissan Connect (had the car a week). New member here, subscribed to the speed cams.
The SD Card info is:
25920 BH00A, 2008 Navteq/Robert Bosch GmbH
I have tried the advice given in this post, yet nothing is recognized, eg. once I plug the USB stick in , the display says - AUX inserted, but thats it. No "loading" screen appears.
Any more thoughts ?
L |
Posted: Fri Jun 12, 2009 12:42 am Post subject: |
ok sorry all, i've done it. rtfm comes to mind! on page 4-19 of the Nissan Connect Owners manual it explains what you need to do. The folders on the usb should be as follows:
x: = your usb drive letter
x:\myPOIs\myPOIWarnings
place the CSV file under the above folder and all works fine
Thanks to suzukiscottie for putting me on the track, however it wasn;t clear the "myPOIWarnings" folder should be created under the "myPOIs" folder...
sorry to have bothered the forums
Best,
L |
