pippol Occasional Visitor
Posted: Mon Apr 27, 2009 5:46 pm Post subject: decompression failure |
Hi my name is Peter and I'm new to the cite. I recently purchased a TomTom XL 340-S. Im using a Mac with Safari browser. When I try to download the free poi's, I get a dialog when I download it which say's decompression failed. Doe's anyone know what my problem is? |
Posted: Mon Apr 27, 2009 5:53 pm Post subject: |
Hi and welcome.
I'm not a Mac user but does this message from the POI Download page help?
Quote: | 2. The selection does not work using Safari on an Apple Mac. The system works with Firefox and Camino on the Mac. The downloaded POI.zip file needs to be dropped into the Stuffit application, it gives an error if opened directly. |
I assume you need a program called Stuffit to unzip the files? Or use Firefox or Camino? |
Posted: Mon Apr 27, 2009 5:55 pm Post subject: |
Welcome to the forum, next to the download button is a small checkbox labeled "Show Link" try ticking this and downloading again it should cure the issue, also keep the number of categories down to around 20 for each download otherwise it will probably fall over - Mike |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon Apr 27, 2009 5:58 pm Post subject: |
Hi, I use a mac and there is a little glitch in the system with Stuffit.
I don't use Safi, I'm FF fan.
I believe that Safi uses by default the Stuffit Archive manager or something to open the file, and this fails.
I download the file to my desktop, right click (ctrl, click) and from the drop down list, use the Stuffit Expander app. Works no problem then.
Hope this helps. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Darren Frequent Visitor
Posted: Mon Apr 27, 2009 7:32 pm Post subject: |
253 wrote: | I believe that Safi uses by default the Stuffit Archive manager or something to open the file, and this fails. |
Almost. Safari uses the built-in archiver.app regardless of what other archive utils you may have installed and it is this that fails.
No matter though, if you have Stuffit installed just right-click the archive and select 'extract', if you don't, it's a free download. _________________ Darren Griffin |
253 Lifetime Member
Posted: Mon Apr 27, 2009 8:51 pm Post subject: |
Darren wrote: | 253 wrote: | I believe that Safi uses by default the Stuffit Archive manager or something to open the file, and this fails. |
No matter though, if you have Stuffit installed just right-click the archive and select 'extract', if you don't, it's a free download. |
Cheers Darren, I thought it was the default from one or the other, couldn't remember which one though. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
