ELGORDO78 Occasional Visitor
Posted: Mon Jun 21, 2004 4:44 pm Post subject: TT3 Datalog Problems |
I'm running TomTom 3 on an Ipaq 2210h, plenty of SD memory, along with a flash gps card on the sirf chipset.
The datalog is bugging me at the moment.
4 weeks ago I successfully copied the log I'd created on a short test-run, to my PC and using Oldie's software changed it to a text file. My only annoyance at all was I'd forgotten to raise the safety speed from 124 so a true top speed wasn't visible ;) (only joking occifer ;) :D )
This weekend I took the unit to Rockingham for a trackday to do a bit of top-speed logging and to see how it generally performed recording lots of direction changes in a short time - as well as providing the topographic data to a friend who creates tracks for PC racing games and hadn't any elevation data for the circuit.
Now with no hardware or software changes at either end of the deal, when I convert there is no speed or course data in the resulting file. However, the GPS Info playback on the handheld show all of this information, so the data is there... The signal ranged from 1 or 2 when inside the steel and concrete garages (and so was greyed out) to between 4 and 9 on-circuit.
Are there any alternatives out there, or can someone try the file for themselves (only 1.4mb) and see if the results differ?
Any help or advice would be apreciated.
Cheers. |
Oldie Pocket GPS Moderator
Joined: 22/11/2002 13:33:48 Posts: 992 Location: Surrey, UK
Posted: Tue Jun 22, 2004 4:22 pm Post subject: |
If you email the file to me then I will have a look at it for you. Also could you tell me the name and version number of the program that you are using.
Richard |
Posted: Sun Jun 27, 2004 11:09 pm Post subject: |
mail on its way |
Posted: Fri Jul 02, 2004 9:45 am Post subject: |
Thank you for sending the log file. LogConverter v1.02 reads the Course and Speed data from the NMEA $GPVTG records and those records are not present in the log file that you sent to me. However, the Course and Speed data are also stored in the $GPRMC records and these are present in your file. So I have modified LogConverter to read both record types. The new version, 1.03, is available for download from my website http://rjdavies.users.btopenworld.com in the Programs area.
Something must have changed in your GPS setup as you were able to extract speed data from a previous log file using v1.02. |
