Pocket GPS World :: View topic - Cliff edge walk - very wrong profile
philpugh
PostPosted: Wed Apr 22, 2009 6:04 pm    Post subject: Cliff edge walk - very wrong profile Reply with quote
I was walking a small part of the Cleveland Way from Robin Hoods Bay to Whitby over Easter (as a light break from the NYM). I planned the walk on SatMaps Routeplanner and the profile looked a bit dodgy - but I wasn't overly bothered. Its a 7.4 mile walk (actual logged distance - the planner has it as 1/2 mile less) but the Active10 reckoned it had 2500 ft of ascent! ( I would have thought no more than 1200-1500 ft) I guess the altitude based of the mapping is a bit suspect when on the edge of cliffs. The plotted tracklog was clearly inside the edge when plotted onto MemoryMap - so it s not down to positional errors. I guess the DEM they have has problems with sheer drops. Nice walk though - even though parts of the marked path are now in the North Sea and they are preparing even more diversions in expectation.
Phil
LostMike
PostPosted: Wed Apr 22, 2009 6:22 pm    Post subject: Reply with quote
The A10 is renowned for getting total ascent far higher than most people would believe. It has been commented on here several times along with a hope that they may come up with a better algorithm.
So if you mean the maximum height you reached less the minimum height then I am surprised but if you mean the A10's estimate of the total height climbed on the walk then I would say it was about par for the course.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
super_claret
PostPosted: Wed Apr 22, 2009 10:01 pm    Post subject: Reply with quote
I am also having problems with the total ascent readings being ridiculously high.
I plotted a route on the Satmap which read total ascents 2100ft but when I actually followed the route the final readings were 4450ft!!!!
I'm sure it is a lot worse after installing the recent update. I personally think this is unacceptable, therefore I'm going to confront Satmap about this. I have one of my data boxes set to tell me the total ascent as I follow my route but I can't rely on this at all.
philpugh
PostPosted: Thu Apr 23, 2009 9:26 am    Post subject: Reply with quote
I'm pretty sure the problem lies with the use of Digital Elevation Model that is supplied with the mapping. Other walks I have done with the Active 10 have the total ascent matching that provided by (for example) a GARMIN Oregon (to within 10ft in a 4300ft total ascent) - so I think it works most of the time. I suspect that the algorithm used can't handle sheer cliffs. The walk is along 7 miles of 150-200ft cliffs (within a few feet of the edge) and I suspect that it sometimes gives a 0ft (or very low) elevation when you get very close to the edge!
On the Satmap route planner the profile doesn't look correct either. I've published the route (Whitby to Robin Hoods Bay - look for those by philpugh) if you want to check it! Some of the 'incorrectness' is caused by the straight line route between the waypoints - but even so it just doesn't seem to match what the map is telling you.
Phil
Physicist
PostPosted: Sun Apr 26, 2009 8:00 pm    Post subject: Reply with quote
I agree with Phil's cliff analysis (I have walked that Cleveland Way path with similar daft ascents). It isn't difficult to eliminate the problem in software; just discard any 'ascents' that are over say 5 m when the GPS updates itself every second. If your GPS height has changed by 100 ft in 1 second you haven't (unless you fell off the cliff!)
satmapian
PostPosted: Tue May 05, 2009 12:25 pm    Post subject: Reply with quote
When planning a route on the Active 10 the profile uses only those heights that were plotted as a waypoint. Therefore to get a closer approximation to the actual total ascent to be covered you need to plot your route using waypoints at every dip and rise.
You can see this for yourself by plotting a route using two only waypoints placed either side of a mountain. You will see that the mountain does not appear on the profile. (I'm used to Anquet software, on which the mountain does appear, therefore waypoints are only needed at changes of direction).
philpugh
PostPosted: Tue May 05, 2009 1:43 pm    Post subject: Reply with quote
Yes but....
This was the profile of the actual walked route - which when plotted onto a MemoryMap map was completely contained on the land side of the cliff and showed a better height profile.
I don't pay much attention to planned walk ascents as I don't litter a walk with waypoints - it gets too cluttered if you print off a map. You can judge the ascent of a route from the contours. I tend to use MemoryMap for route planning but decided to try out the Satmap version as it is simpler to share routes that way.
Phil
satmapian
PostPosted: Tue May 05, 2009 3:46 pm    Post subject: Reply with quote
Sorry Phil I was really aiming my observation at Super_Claret's comments, and I should have been clearer.
I accept what you say. I also take height data with a pinch of salt when near cliffs and crags while out on the hill.
philpugh
PostPosted: Wed May 06, 2009 4:51 pm    Post subject: Reply with quote
That's OK !
Phil
4ndynorfolk
PostPosted: Thu Jun 18, 2009 9:22 pm    Post subject: Reply with quote
I climbed Helvelynn from Thirlsmere Swirl on Tuesday (fantastic visibility - could see Blackpool).
My Active 10 was set as usual to read elevation from maps. As I climbed the elevation would not change for ages, and would then jump 80 or 90 metres. Looking at the profile as I went up, the first 600m had just 5 or 6 steps. I changed the setting to take the gps reading and continued.
When I spoke to Satmap yesterday, I discovered that the height fom maps is not an interpolation of the contour lines as I had assumed. Instead, it calculates a weighted average height from the nearest 4 points on an OS supllied grid with 200m point spacing. This was what was causing my strange readings. I was also surprised to find that this data in part of thr firmware of the Active 10, rather than supplied on the relevant map card.
I was told bt Satmap that they were switching to NASA supplied data using a 90m grid. This will 'probably' be in the next update.
I know this does not explain the iffy ascent calculations, but it does explain phipugh's cliff edge issue.
Tony_P1
PostPosted: Fri Jun 19, 2009 9:03 am    Post subject: Reply with quote
I had heard that the height grid was very wide, which explains why I can stand next to a trig point and be 10s of metres out when using altitude from maps. Consequently I always use altitude from GPS. Contrary to what the SatMap manual says, I find this is very accurate in most circumstances giving heights very close to the trig point/contour values. The base of cliffs and the bottom of ravines are not so good, but the map altitudes would be lousy there as well. Cliff tops and hills are spot on.
Tony
FrequentFlyer
PostPosted: Fri Jun 19, 2009 4:51 pm    Post subject: Reply with quote
Tony
Not in my experience...just back from the Pyrenees....took my Satmap set to GPS calculation re. height as obviously, I didn't have any Spanish maps installed. The total ascents and descents each day just don't make any sense at all...totally way out. I still have each days walking as a saved route, so at least I can see each days profile, which at first glance looks fine, but on looking closer............
Tony_P1
PostPosted: Fri Jun 19, 2009 6:47 pm    Post subject: Reply with quote
I think there are two issues. I find that the A10 GPS altitude is closer to the actual height than is the A10 Map altitude. However, in my experience NEITHER method gives values for total ascent and descent that bear any relation to reality. Its something that Satmap should really sort out as in my view this is a major failing. I was walking in Tenerife recently, and took my old Garmin 60csx as I can trust its total ascent/descent. In the UK I have to download the A10 tracks to Memory Map and get the ascent descent from that.
Tony
22.062 (12 Jun 24)
