Mike777 Regular Visitor
Posted: Mon Apr 20, 2009 12:43 pm Post subject: Active 10 GPS tracking cutting corners |
Hi all
Having just views a bike route from my Active 10 I was surprised by the amount of large corners which were cut off my route and just shown as a straight line between two points. My speed was not that fast as to account for me taking the corner within 4 seconds which I believe to the time for each update.
Anyone else come across this and any suggestions on a fix ?
Many thanks for your time and regards
Mike |
PloddinPedro Regular Visitor
Posted: Mon Apr 20, 2009 1:53 pm Post subject: Re: Active 10 GPS tracking cutting corners |
Mike777 wrote: | Having just views a bike route from my Active 10 I was surprised by the amount of large corners which were cut off my route and just shown as a straight line between two points. My speed was not that fast as to account for me taking the corner within 4 seconds which I believe to the time for each update. | Are you looking at the converted .map file or the full "raw" file?
Also, which software version do you have on your A10? |
Posted: Mon Apr 20, 2009 4:36 pm Post subject: |
Thanks for the reply.............
I am using the smaller file of the two I did wonder what the raw data was ?
Software version was update 6 weeks ago so i presume I have the lastest.
Kind regards
Mike |
Posted: Mon Apr 20, 2009 5:27 pm Post subject: |
Mike777 wrote: |
I am using the smaller file of the two I did wonder what the raw data was ? | The raw file contains vastly more data, hence the much larger file size. The .map file is fine for recording tracks as you walk, but as you've found, a cyclist typically covers the ground just a bit too fast for the trail trackpoints, especially in powersave mode, when fewer are recorded. Although you get a perfectly usable record, it can cut corners a bit. It also depends how you are viewing your recorded tracks. I use the raw file and throw it up onto Memory Map. If I want to keep it and I want smaller files, I can filter down the trackpoint numbers in M. Map.
Mike777 wrote: | Software version was update 6 weeks ago so i presume I have the lastest. | If you look in Settings/About it will display the software version. You should now be on version 1.323. |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Posted: Tue Apr 21, 2009 5:36 pm Post subject: |
It will also depend upon your power saving options. With these you can have a setting where you are logging only every 4 seconds - fine for walking but noticeable on a bike. _________________ Phil |
