tigerbear Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_matrix_016.jpg)
Posted: Tue Apr 14, 2009 8:25 pm Post subject: TT 720 screen |
Hi All.. TT 720 screen that alt gently flashes brighter/dimmer every half second or so but not so that you cant use it, its more annoying that anything... Has anyone else noticed or had same thing please..? It has latest software updates and GPS fix and MapShares etc... and it hasnt been dropped....
Many Thanks.. Steve ( tigerbear) Stockton on Tees |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Tue Apr 14, 2009 8:48 pm Post subject: |
Firstly are you using the device with the car charger? if not does the same behaviour exist with the car charger connected?
Secondly when the screen dips in brightness is there a message flashing up top right (white text on a black back ground) - Mike |
Posted: Sun Apr 19, 2009 2:23 pm Post subject: TT 720 |
Thanks for reply Mike.. It only does it with the car charger plugged in and have tried with other TT chargers and its same... No other problems arise no warnings etc just a rythmic gentle flashing bright/dim... All functions work fine.. its just annoying haha thanks Steve |
Andy_P Pocket GPS Moderator
Posted: Sun Apr 19, 2009 9:00 pm Post subject: |
Sounds like a hardware fault to me. ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Alabama978 Lifetime Member
![](modules/Forums/images/avatars/gallery/1_tomtom_x20.jpg)
Posted: Sun Apr 19, 2009 9:15 pm Post subject: Voltage |
This is a long shot but could it be that the vehicle is putting a varying voltage out through the cigar lighter that the TT can't regulate?
Does it happen when the engine is stopped but the charger still powered up or only when the engine is running?
I may be talking gibberish here but if you have a multimeter try to measure the voltage out of the cigar lighter. It should remain steady and not move up and down too much. Another check would be to try the TT in another vehicle, and if it still does it and you have tried two different TT chargers then I suspect it's the TT.
Did you definitely try an actual TT charger when you substituted for the charger you have? I ask because some phone chargers with Mini USB plug do not have a high enough current output even for other phone types. My Tytn would not charge from a 3rd party charger even though it charged other phones without a problem.
Hope you find the cause. |
billyking Occasional Visitor
Posted: Sun Apr 19, 2009 11:51 pm Post subject: |
select screen brightness in the menu and untick the two boxes
that cured my 720 |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Mon Apr 20, 2009 8:29 am Post subject: |
If it's any sort of clue, mine flashes like that while it's loading the mp3s into the Jukebox. _________________ TT Go Essential |
Posted: Mon Apr 20, 2009 8:53 am Post subject: TT 720 |
Thanks Guys... Different vehicles ( fleet driver ) but i shall look at all the sugestions here.. I shall post if I cure it or discover any other differences.. Many Thanks.. Steve |
jimbo_hippo Frequent Visitor
![](modules/Forums/images/avatars/21077135774339845938047.gif)
Posted: Mon Apr 20, 2009 12:48 pm Post subject: |
Tigerbear,
Have you got the latest software on this (these?) devices?
This was in a previous software release. It drove me nuts and I think I wound back to a previous version. It was like someone randomly openng some venetian blinds in your peripheral vision! Most prvelant when on battery. Current 8.302 doesnt do it (at least when powered). might be worth checking which version is installed. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
Posted: Thu Apr 23, 2009 10:01 am Post subject: 720 screen |
Hi All... The unit is with a friend at the mo he is borrowing it i shall check the software version when it comes back.... I am sure its latest but shall check.. thanks guys for all your replies.. good to know so many out there to help if needed... Only hope i can return the favour one day.. Cheers
steve Tigerbear Stockton On Tees |
