Pocket GPS World :: View topic - Fitting a brodit mount
MarkHewitt
PostPosted: Fri Apr 17, 2009 9:59 am    Post subject: Fitting a brodit mount Reply with quote
I might just be being stupid here, but I'm stuck
I have a proclip fitted into my car, that's all fine. And I have an attachment for my N96 which the phone fits into just fine.
The instructions say take off the backing plate and screw it to the pro-clip. How? The proclip has no holes in it and is very thick plastic. Do I need to start drilling holes into it?
GerryC
PostPosted: Fri Apr 17, 2009 10:15 am    Post subject: Reply with quote
There should be some self tapping screws with the N96 attachment. These should screw into to Proclip without having to drill. You may want to make a pilot hole to get the positioning right though. Taking the backing plate off is just so that you can access the holes easier.
Though I've used Proclip mounts for several years, I've always used the "moveclip" which lets you swap devices and is held on with adhesive pads.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
MarkHewitt
PostPosted: Fri Apr 17, 2009 10:23 am    Post subject: Reply with quote
Strange. I tried screwing them in very very hard but they barely scratch the surface!
GerryC
PostPosted: Fri Apr 17, 2009 10:53 am    Post subject: Reply with quote
You could use double-sided adhesive pads - probably from a DIY store etc.
If you're not worried about taking them apart again, superglue may work. Shocked
As I said, I've never tried screwing it together so was going by what I remembered the instructions saying. Embarassed
Gerry
TomTom730T
PostPosted: Fri Apr 17, 2009 10:54 am    Post subject: Reply with quote
They can be tricky but I've never had to pre-frill the holes but you may find it easier if you do.
However I now use 'MOVE' clips instead. These affix using adhesive pads to the mount and cradle and allow quick removal as necessary.
PostPosted: Fri Apr 17, 2009 8:05 pm    Post subject: Re: Fitting a brodit mount Reply with quote
No, you're not alone, Mark...
When I bought a Brodit Proclip and TomTom mount, I got the feeling I'd been given a half-finished kit of parts, which would definitely have needed a drill (and some shorter screws!) to make a decent finished result.
In the end I got a 'move clip' instead, which used a sticky pad onto the dash and was very successful.
Strangely enough, the 'move clip' DID have screw holes on just one half... which weren't needed! Stop it!
PostPosted: Fri Apr 17, 2009 10:15 pm    Post subject: Reply with quote
The screws will go in to the hard plastic but you do need to use quite a bit of force, the four supplied scews are very sharp, although I have never needed "frilly holes" to put them in - Mike
PostPosted: Fri Apr 17, 2009 11:41 pm    Post subject: Reply with quote
Wink
PostPosted: Sat Apr 18, 2009 9:39 am    Post subject: Reply with quote
Darn it, I was replying from the phone!
PostPosted: Sun Apr 19, 2009 11:45 pm    Post subject: Reply with quote
I posted a couple of info threads earlier today that detail fitting the Brodit kit to a car, perhaps you might want to have a look at This Or This One
But I have to agree those little screws are far from easy to get in to the plastic face of the Pro-Clip, I did consider the move it clips as I have used them on previous installations but decided a fixed install was probably best for the time being - Mike
MarkHewitt
PostPosted: Thu May 07, 2009 1:37 pm    Post subject: Reply with quote
Thanks for all the replies. I'll just have to have a go at using the forceful approach then. I was sure I was doing something wrong or I'd been sent the wrong parts!
PostPosted: Thu May 07, 2009 1:48 pm    Post subject: Reply with quote
Try fitting the two parts together with the Pro-Clip in a vice or similar, this way if you slip with the screwdriver you won't damage the cars trim - Mike
23.031 (05 Mar 25)
