Pocket GPS World :: View topic - The clock is wrong. No daylight saving?
pEst_29
PostPosted: Wed Apr 01, 2009 11:06 pm    Post subject: The clock is wrong. No daylight saving? Reply with quote
I used my TomTom Go 730 today after some days of inactivity and when I was preparing a route, I realised it thought it was 1st of January 1970. The time was also 1hr behind. After an hour driving, the time was still wrong. I did a reset and after that, after it got a lock, I could see it had the right date. However, it's still one hour behind! How can I fix this?
Paul80
PostPosted: Wed Apr 01, 2009 11:23 pm    Post subject: Reply with quote
Adjust the time in prefrenses
PostPosted: Wed Apr 01, 2009 11:31 pm    Post subject: Reply with quote
It needs a GPS fix to work out the correct date and time of day for the IQ routes to function correctly Wink After that you need to correct the local time zone as the device uses UTC Time which remains constant all year round unlike our stupid clock based time - Mike
pEst_29
PostPosted: Thu Apr 02, 2009 12:43 am    Post subject: Reply with quote
How do I correct the local time zone?
dhn
PostPosted: Thu Apr 02, 2009 12:58 am    Post subject: Reply with quote
Click on the 'Profile' button at the top of this screen. Scroll half way down to where the Time Zone setting field is. Adjust accordingly and save.
PostPosted: Thu Apr 02, 2009 6:33 am    Post subject: Reply with quote
The OP is referring to the time on the 730. Wink
It's in Change Preferences | Set Clock.
2nd Page of Menu adjust hours setting by pressing "up" once. Press "Done" twice.
dhn
PostPosted: Thu Apr 02, 2009 11:23 am    Post subject: Reply with quote
Embarassed Embarassed Embarassed
pEst_29
PostPosted: Thu Apr 02, 2009 5:41 pm    Post subject: Reply with quote
Blimey I couldn't find that option yesterday! Sure it's there? Will look again tonight...
Thanks!
PostPosted: Thu Apr 02, 2009 5:54 pm    Post subject: Reply with quote
You should have 7 or 8 pages of options in change preferences if it's less than this try change preferences/ show all menu options otherwise the clock option might be missing - Mike
cleggie
PostPosted: Thu Apr 02, 2009 6:12 pm    Post subject: Reply with quote
I did it manually the other day when the clocks went forward.But just checked today and i turned the clock back an hour first,then i pressed the sync button and it did it to the correct time ie GMT +1 hour.
So it must use daylight savings.
This is for UK
Try it
pEst_29
PostPosted: Thu Apr 02, 2009 9:24 pm    Post subject: Reply with quote
Thanks everyone, sorted now. Can't believe I missed that option yesterday, I guess I got too tired to pay attention before I got to the eight page of the Prefs menu!
PostPosted: Thu Apr 02, 2009 11:11 pm    Post subject: Reply with quote
This is for UK
Try it
It doesn't...
Once you have set the hours yourself, the "sync" button only synchronises the minutes.
Try it by changing the hours to something completely wrong then press "sync".
pEst_29
PostPosted: Thu Apr 02, 2009 11:47 pm    Post subject: Reply with quote
This is for UK
Try it
It doesn't...
Sync didn't work for me. I went to my balcony until I had s satellite lock, then pressed Sync but nothing happened, several times. I don't know if I had to wait quite a lot longer? I just did it manually...
Daggers
PostPosted: Thu Apr 02, 2009 11:48 pm    Post subject: Reply with quote
It's not quite as straightforward as this. If you change the time, then press the Sync button before pressing Done, it resets the hours to what they were before.
However, if you change the time, press Done, then go back and press Sync, no changes are made to the hour.
Garmin DriveSmart 50 LMT-D
