Pocket GPS World :: View topic - iGO8 Ultra Skin 6.0.22
Goto page Previous  1, 2, 3 ... 22, 23, 24 ... 33, 34, 35  Next
gizmo2155
PostPosted: Sat Mar 28, 2009 11:35 am    Post subject: voices dont work Reply with quote
I was using igo8 8.0 with ultra skin 5 and all worked a treat.
I have now upgraded to IGO8_8.3.2.79297 and ultraskin 6.0.21 and I cannot get the speed camera voices to work.
If I use the GJ5.4 skin i get all the options, shows the cameras and allows me to select the voice though when i press test the only one that works is the overspeed sound, the rest give no sound at all.
Using the ultraskin 6.0.21 i get no options for voice settings what so ever.
Any ideas ?
linknet
PostPosted: Sat Mar 28, 2009 11:46 am    Post subject: Re: voices dont work Reply with quote
gizmo2155 wrote:
There are no speed camera voices in Ultra Skin 6.0.xx Wink
linknet
ciberyan
PostPosted: Sat Mar 28, 2009 7:04 pm    Post subject: Reply with quote
Hi all
Thanks Linknet for your advice for silent voice, everything is ok.
Is there a mean, sys or skin to do the following :
Disable the upper big coloured sign to keep only the lane indicator ?
set the different volume at start up , (general, voice, and key touch)
I have systematically the voice at 0 and the key a 100%
Thanks for your help and your very good job
linknet
PostPosted: Sat Mar 28, 2009 7:25 pm    Post subject: Reply with quote
I think you need to add this to BOTH copies of sys.txt:
[interface]
laneinfo_signpost_enabled=0
ciberyan wrote:
Set the different volume at start up , (general, voice, and key touch)
I don't quite understand what you want here, you can set all of these on the sound settings menu. Confused
Regards
linknet
hyz
PostPosted: Sat Mar 28, 2009 10:59 pm    Post subject: need help: how to make the igo8 display highway exit number Reply with quote
the top of screen show the highway exit number that will be taken.
but it never display any other highway exit number on the map.
Is it possible to show the current exit number on the map.
This will help me to know my current position.
Thank you in advance
linknet
PostPosted: Sat Mar 28, 2009 11:19 pm    Post subject: Re: need help: how to make the igo8 display highway exit num Reply with quote
Not as far as I know. It is possible to enable items on the map with settings in the "sys.txt" file, but I haven't seen one for the highway exit numbers.
linknet
PostPosted: Sat Mar 28, 2009 11:23 pm    Post subject: Reply with quote
Hi Linknet.
Do you know if there is a method to get the lane indication boxes to come up earlier. They appear only just before you get to the turn off/straight ond (depending on route)?
linknet
PostPosted: Sat Mar 28, 2009 11:43 pm    Post subject: Reply with quote
Hi Linknet.
That's strange, I've always found them appearing way in advance of any turn. As far as I can determine they are dependent on the map data and there is no way of adjusting the timing.
Regards
linknet
PostPosted: Sun Mar 29, 2009 12:15 am    Post subject: Reply with quote
Thanks for the reply. That's what I thought. It's the little square arrow thingies that I refer to. These seem to pop up far too late. The big signposts at the top are fine and generally pop up a long way from the junction as you say. h well!!!! Crying or Very sad
ciberyan
PostPosted: Sun Mar 29, 2009 8:51 am    Post subject: Reply with quote
Regards
linknet
In fact my problem is that those settings are NEVER saved ...
Was not not depending of Igo version, I dont understand why ...
This is the reason I look for a way to set it in init files
ciberyan
PostPosted: Sun Mar 29, 2009 8:54 am    Post subject: Reply with quote
[interface]
linknet
Any chance to have a button in the skin to toggle that ??
Is there a directory of the special command available in sys.txt and their use ??
linknet
PostPosted: Sun Mar 29, 2009 9:16 am    Post subject: Reply with quote
Was not not depending of Igo version, I don't understand why ...
Are all the other settings saved ? If not then maybe the SD Card is write protected.
Have you got "Use Device Settings" enabled ? This may affect the sound settings.
linknet
linknet
PostPosted: Sun Mar 29, 2009 9:39 am    Post subject: Reply with quote
ciberyan wrote:
[interface]
If I add a button it will only disable the signpost information and you won't see this information in the lane arrows.
If you use the above setting it will hide the signpost information and then show the information in the lane arrows instead.
There are lot's of them, try a google search or search this forum.
linknet
ciberyan
PostPosted: Mon Mar 30, 2009 6:41 am    Post subject: Reply with quote
Thanks for signpost trick, it works, display is more clear for me now
Only complain is about the lane infos which, personnaly, I find with not enough contrast for guy like me, who need glasses on the nose to look near object !
a flashy green and red could be better ? anyway to modified that by ourselves to adapt ?
Thanks !
linknet
PostPosted: Mon Mar 30, 2009 8:31 am    Post subject: Reply with quote
Thanks !
You could change the transparency by editing all of the background files in the skin:
You'll find a total of 8 files, 4 of each type. You need to decompress them with "rlec.exe" and then lighten the alpha layer for each file.
linknet
Page 23 of 35
22.094 (25 Sep 24)
