Pocket GPS World :: View topic - IPAQ 2210 ISSUES
IPAQ 2210 ISSUES
wakaday
PostPosted: Sat Jun 19, 2004 4:32 pm    Post subject: IPAQ 2210 ISSUES Reply with quote
I'm running an IPAQ 2210 v1.1 with TT3. I've had a few annoying problems with the kit. The unit has perfomed a factory reset for no reason twice in the last few months, the clock resets itself. With TT3 the volume turns itself off. The back light illumination turns itself to min with the external power connected. Why does the equipment do this or does it have a mine of it's own. Any comments appretiated.
Whitebeam
PostPosted: Sat Jun 19, 2004 5:49 pm    Post subject: Reply with quote
Until someone a bit more knowledgeable comes along .....
Factory resets.
Check that your battery is mounted properly and the connections are clean. You can take the battery out to check (unit should run on the internal battery for a while). Do you know the battery(s) state when this happened? Other possibility is a hardware fault.
TT3 volume. Does the volume go to zero / become unchecked (file / properties / navigation) or is there no sound? If the later, are you in navigation mode when this (doesn't) happen? (voice instructions only work in nav mode).
Backlight. there are two backlight settings - battery & external power.
Go to : settings / system / backlight / brightness.
Hope this helps.
alix776
PostPosted: Sat Jun 19, 2004 6:08 pm    Post subject: Reply with quote
tis sounds more like an ipaq probblem than a tomtom one try the installing the lastest rom for the hp site but do a full back up before you do install the new rom
device Lumia 950 xl
wakaday
PostPosted: Sat Jun 19, 2004 6:55 pm    Post subject: Reply with quote
I understand how to set power mgt, time, tt voice commands. The problem is that my settings change by themseleves.
I'm running the latest HP ROM v1.1.
rampantrabbit
PostPosted: Sat Jun 19, 2004 9:12 pm    Post subject: Re: IPAQ 2210 ISSUES Reply with quote
I also have TT3 on an Ipaq 2210, it does not suffer with factory resets but it does keep unchecking the sound within TT3 without any reason. once i re-enable it it will run for a while.
Rab
Ipaq 2210, TTM 3 wired GPS, 256mb CF & TTM 3 Car Kit
Fraserp
PostPosted: Sat Jun 19, 2004 9:53 pm    Post subject: Reply with quote
There appear to be several reported incidents of TomTom loosing or changing its properties settings for no apparent reason. i certainly have had this happen several times.
If it happens, dont forget to log it with TomTom support.
The only people who will fix it are TomTom.
Fraserp
TomTom 1000
GPSmap 60CSx
SatMap
iancjc
PostPosted: Sat Jun 19, 2004 9:58 pm    Post subject: Reply with quote
the problem for tomtom is that for people like me TTN3 on a 2210 runs very well (problems with the app/map/traffic excluded). I get no lockups no bt problems and no dropouts.
I think that the 2210 is probably the most popular current ipaq and therefore shows the most problems
TTN6.03 tomtom 7.xx (one)
