Drift Occasional Visitor
Posted: Sun Mar 22, 2009 4:37 pm Post subject: Copilot 7 freezes |
On my 02 Orbit2, I get as far as setting the route but when I hit the drive button the icon shows like its loading but just sticks then after a few minutes closes down, just once it loaded but 5 minutes into the journey it froze and shut down.
I cant think of anything Ive done to alter the settings.
It was interesting using an old paper map yesterday .
Any ideas ?
Cheers. _________________ Ste
Gone for simples and now have TomTom One V3 1gig
Memory Map V5 on laptop and GPS.
I couldnt get on with Copilot V8 |
alix776 Pocket GPS Moderator
Posted: Sun Mar 22, 2009 6:23 pm Post subject: |
it could be the device running out of memory make sure you have as little as possible running at the same time as cp7 is very memory hungry _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
reteb Occasional Visitor
Posted: Sun Mar 22, 2009 7:50 pm Post subject: |
Not sure if it's the same problem I get, but I use CoPilot Live. Unfortunately, if you are in an area with an intermittent phone signal CoPilot shuts down soon after the signal is lost. The answer to this problem is to decrease the frequency that is used in the Live setup to something like 1 minute (or maybe switch off Live altogether). |
Posted: Sun Mar 22, 2009 7:55 pm Post subject: |
I checked and I dont have any programs running when Copilot is running.
I very rarely use live as I get fed up of the icon popping up on the screen when it looses a signal and it wont go away, most frustrating.
Thanks. _________________ Ste
Posted: Fri Mar 27, 2009 12:43 am Post subject: |
I had cause to hard reset my pda because of an unrelated problem, and bingo, it works fine after being re installed, thought might and didnt want to go down that route but another application forced me to. _________________ Ste
Posted: Sat Jun 20, 2009 2:36 pm Post subject: |
A new twist to this, Ive found recently that when I use ALK EZP File (.ezp) (copied into the correct folder) safety camera updates, this causes the program to freeze up in the same way until I delete the safety camera file then it runs ok.
Does any one have a cure for this\/ _________________ Ste
nivek22 Lifetime Member
Joined: Mar 09, 2006 Posts: 194 Location: Barnsley, South Yorkshire.
Posted: Sat Jun 20, 2009 7:54 pm Post subject: |
Try a soft reset prior to running coPilot to free up as much memory as possible. |
Posted: Sat Jun 20, 2009 8:32 pm Post subject: |
Hi Niv, Ive done the soft reset, I also have a ram clean program but didnt make any difference. _________________ Ste
Posted: Sat Jun 20, 2009 8:50 pm Post subject: |
it runs fine on my orbit 2 have you got this update ( i dont know if this is the same version as you are running) but it could be worth a try
click here _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jun 20, 2009 9:19 pm Post subject: |
Mine is only 6 months old with windows 6.1 professional xda Orbit11 so I should think that update would be already included? possibly. _________________ Ste
Posted: Sat Jun 20, 2009 9:37 pm Post subject: |
are you using the copilot speed cams or or the pgpsw speed cams _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jun 20, 2009 10:28 pm Post subject: |
Ive been using the Copilot cams _________________ Ste
Posted: Sun Jun 21, 2009 11:15 am Post subject: |
try the pgpsw ones ive not had a problem with them have you disabling the show pois from the map display _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Jun 21, 2009 11:19 am Post subject: |
Ive not disabled poi, I only use the fuel station poi.
Not used PGPSW files as yet. _________________ Ste
homecamp Occasional Visitor
Posted: Sun Jun 21, 2009 10:57 pm Post subject: |
Mine does that all the time. Crashes for no reason with no warning. Usually in the most awkward place. I've tried various ROM and Radio ROM on my Touch Diamond. There's plenty of RAM and space available. CPL7 is riddled with nasty bugs.
It especially hates it when it can't establish a GPRS connection for its Live or traffic feed. In some parts of the country with no mobile signal, I can't get CPL7 to start at all unless I manage to disable the traffic connection first.
I have tried raising this to ALK but they just don't care.
Not seen the camera problem. I use both databases but CPL7 crashes with and without the cameras.
Looking for an alternative to CPL7 before I throw my smartphone through the window. |
