Pocket GPS World :: View topic - Power Pack Discharge
marcelus54
PostPosted: Mon Mar 23, 2009 10:12 pm    Post subject: Power Pack Discharge Reply with quote
I use the satmap rechargeable battery pack. I have noticed that on occasion it completely discharges itself.
I.E. it was 3 parts charged on Saturday when I replaced my Cache, Turned it on tonight only to find it was closing down due to low battery charge?
Am I alone in this, it has happened 3 or 4 times now.
nonoftheabove
PostPosted: Tue Mar 24, 2009 10:04 am    Post subject: Reply with quote
Did you actually switch it offf after unplugging the charger from the device.
I mention this as i have in the past charged it on a previous evening to a walk next day.
Only to find that at walk start No green bands but a message stating switching off in next x minutes. Its the fact that the unit NEEDS to be switched OFF after charging IF you are not planning to go walking there and then.
marcelus54
PostPosted: Tue Mar 24, 2009 2:01 pm    Post subject: Battery Discharge Reply with quote
I was wondering if it is a case of me not switching it off properly. I have now given it a full recharge, 4 bars full and have switched the unit off and put it in its case until Saturday morning when I will load up a new Pocket Query. I will advise on the state of charge then.
I do not believe I have left it on by mistake. I will repost later.
Thanks nonoftheabove for your reply
4ndynorfolk
PostPosted: Tue Mar 24, 2009 6:23 pm    Post subject: Reply with quote
I can't find it now, but someone reported here that, Satmap had told them they, where bringing out a solar charger to charge a spare battery while using the Active 10. It may have been Darren or Mike.
I can't believe that this would rely on the delicate little plug and socket arrangement, which not designed to be used more than a few times.
By implication therefore, it suggests that a more user friendly method of battery connection is being considered. A mobile phone type arrangement has been suggested elsewhere in this forum.
I am considering moving to the li-pol battery pack but have always been put off by the prospect of running out of battery mid walk and having to try and fit a spare or the AA cradle in the wild. This would resolve this issue.
Any further information would be great. I would hate to buy one just before the design changed.
Mike: dare I ask you add it to your list of questions for the show please?
4ndy
philpugh
PostPosted: Tue Mar 24, 2009 7:35 pm    Post subject: Reply with quote
Unless you are doing very long walks it won't be a problem.
First real test with my li-pol pack on Saturday. It was on for 9hrs 45mins continuously and had lost just the one bar on the battery meter. Good for a few hours more than that I reckon.
No - you wouldn't want to be messing about with the battery cradles in the wild. They seem much too delicate for that.
Phil
Bosun
PostPosted: Tue Mar 24, 2009 10:28 pm    Post subject: Reply with quote
I am surprised that the Li-Pol battery/battery cradle connector ever got past quality control,it looks so fragile.
Surely it should be possible to change a battery or cure a lock up ( now much rarer ) "on the hoof" if need be without fiddling with such a device.
Having said that though I have connected/disconnected it a few times and it is still OK.Perhaps it is stronger than it looks.
ian
PostPosted: Tue Mar 24, 2009 11:10 pm    Post subject: Reply with quote
First I've heard of it. I have used my PowerMonkey to top up my Active10 whilst on walks where I had forgot to re-charge before-hand and it worked fine though.
4ndynorfolk
PostPosted: Tue Mar 24, 2009 11:47 pm    Post subject: Reply with quote
Found the original reference to a solar charger.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=74374
The first part, world mapping has started to materialize.
PostPosted: Wed Mar 25, 2009 8:32 am    Post subject: Reply with quote
So
or that event, we are developing a solar charger which will trickle charge a spare rechargeable battery
Doesn't state it's a LiPo so could just be a charger for standard AA rechargeable types.
johno99
PostPosted: Wed Mar 25, 2009 9:37 am    Post subject: Reply with quote
Phil
Hope you dont try uploading your 9hr 45min walk onto the route planner, that would really lock it up!
John
philpugh
PostPosted: Thu Mar 26, 2009 3:00 pm    Post subject: Reply with quote
johno99 wrote:
Phil
John
Should be posting (or rather publishing it, as it's already on the Satmap route planner site) this weekend. The on-line planner didn't take too long to 'plan' it! There are less than 25 waypoints split between the main route and two optional finish routes. I only place waypoints where it looks like they will be needed - it comes from working with early GPS units that had very limited numbers of waypoints / route!
Total distance of all three 'routes' is 30ish Kms. We ended up walking just short of 20kms - mainly because the pub (the excellent Bridge Hotel in Buttermere) was 0.5Km before the planned end of the walk - and I turned everything off! I was logging with the Active10 and my GPS logger - both tracks were virtually identical.
Phil
johno99
PostPosted: Thu Mar 26, 2009 4:09 pm    Post subject: Reply with quote
Phil
I agree using the on line planner to plan a route couldnt be easier I was impressed with how easy it was. I choose to put the minimum of waypoints as well after all I dont want to be following the device from tree to tree exactly would take all the fun out of exploring. My father in law who is 78 would not touch a satnav device he prefers to find his own way and has a lot of fun doing it.
The problem appears to be when uploading from the active 10 to the route planner, the device chooses the waypoints and as I have stated 480 odd over a fairly short cycle ride. Because of the size the route planner cant handle it. Satmap are working on it and have replied once 2 days ago asking me to try it as they had increased the capacity but it still didnt work. I have replied to them and hopefully they can come up with a fix.
Didnt see anything about that on FAQs.
22.124 (26 Dec 24)
