Dawks Occasional Visitor
Posted: Sat Mar 21, 2009 1:09 pm Post subject: |
I've done EXACTLY as per your instructions Linknet including renaming the file etc etc and when you try and select the Silent Voice in igo it is certainly NOT in the list to select. However the one that you uploaded is in the list and can be selected. For whatever reasons if you use your file as a template for a female voice it most certainly does not work! Deleting the .ogg files in a voice file that I want to use, then just leaving the 2 .ogg files simply doesn't work either! |
M8TJT The Other Tired Old Man
Posted: Sat Mar 21, 2009 1:10 pm Post subject: |
Aha, I see. Of course. It seems that Igo picks up the voice file pretty much regardless of what the file is called and picks up the name displayed on the Igo from the info.ini file within the .zip file rather than the zip filename itself. This is also true of skins in the skins folder. |
Posted: Sat Mar 21, 2009 1:16 pm Post subject: |
Dawks wrote: | Deleting the .ogg files in a voice file that I want to use, then just leaving the 2 .ogg files simply doesn't work either! |
When you say 'doesn't work either' do you mean that you still get the voice commands? If so, as I said before, to which linknet replied, you MUST have another copy lurking about somewhere. If that is not the case, I'll wind my neck in and carry on lurking. |
linknet Frequent Visitor
Posted: Sat Mar 21, 2009 1:39 pm Post subject: |
Dawks wrote: | I've done EXACTLY as per your instructions Linknet including renaming the file etc etc and when you try and select the Silent Voice in igo it is certainly NOT in the list to select. However the one that you uploaded is in the list and can be selected. For whatever reasons if you use your file as a template for a female voice it most certainly does not work! Deleting the .ogg files in a voice file that I want to use, then just leaving the 2 .ogg files simply doesn't work either! |
This is veering towards pantomime mode, so....
Oh yes it does work.
linknet |
Posted: Sat Mar 21, 2009 2:34 pm Post subject: |
Well for fear of repeating myself if I could see the voice in the list in igo then I would at least have a chance of selecting it to see if it does work. Can we have some clear instructions please, as so far none of the instructions that I have seen have worked. |
Posted: Sat Mar 21, 2009 2:42 pm Post subject: |
I see there is lot of interest for silent voice
Sorry for not answering, was away from a pc
My language is french with female usually so It would be great if you can also send me a file I can use as a guide. deleting all the ogg doesnt work for me last time
Thanks in advance
That is of course unless both ciberyan and me are making up some kind of a story Linknet!! |
Posted: Sat Mar 21, 2009 2:51 pm Post subject: |
Dawks wrote: | Well for fear of repeating myself if I could see the voice in the list in igo then I would at least have a chance of selecting it to see if it does work. Can we have some clear instructions please, as so far none of the instructions that I have seen have worked. |
The instructions are very clear and unambiguous, if you follow them correctly then the voice will show in the selection list.
You must be making some very basic error somewhere, so instead of complaining about the instructions check the procedure you have used carefully.
Why not post a link to the voice file you have modified ?
linknet |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sat Mar 21, 2009 5:22 pm Post subject: |
linknet wrote: | Dawks wrote: | I've done EXACTLY as per your instructions Linknet including renaming the file etc etc and when you try and select the Silent Voice in igo it is certainly NOT in the list to select. However the one that you uploaded is in the list and can be selected. For whatever reasons if you use your file as a template for a female voice it most certainly does not work! Deleting the .ogg files in a voice file that I want to use, then just leaving the 2 .ogg files simply doesn't work either! |
linknet |
My monies on linknet being correct.
What some people have to remember is, linknet spends a lot of time with his Skins and everyone should be grateful for him passing them on FREE.
If you ask for something extra and linknet says he's not doing it, just accept it and be grateful for what he does do.
For those people who aren't happy, why not revert to Default skin or teach yourself how to add any extras they require. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Sat Mar 21, 2009 6:13 pm Post subject: |
I'm not a complete idiot and in fact I work in an IT based industry. I certainly do appreciate what Linknet does that's for sure. What I don't appreciate is being patronised by people assuming that I am not following instructions; instructions that simply don't work. |
Posted: Sat Mar 21, 2009 6:48 pm Post subject: |
Firstly, you haven't changed the "languagename" field as per the instruction below:
3. Now edit the info.ini file to rename the voice. Change the voicekey and languagename fields to whatever you prefer (just adding "Silent" to the end of the name works fine).
Secondly, and the main problem, you've made the very basic error of zipping the "Voice_Eng-uk-f3-Silent" folder itself inside the "Voice_Eng-uk-f3-Silent.zip" file.
linknet |
Posted: Sat Mar 21, 2009 7:17 pm Post subject: |
I have renamed the languagename. The "Voice_Eng-uk-f3-Silent.zip" file.
was in another folder when it was uploaded through Rapidshare, however in the igo voice folder it is zipped exactly the same as all the others.
It still doesn't work.
Lets just leave it anyway thank you. |
Posted: Sat Mar 21, 2009 7:49 pm Post subject: |
Dawks wrote: | I'm not a complete idiot and in fact I work in an IT based industry. I certainly do appreciate what Linknet does that's for sure. What I don't appreciate is being patronised by people assuming that I am not following instructions; instructions that simply don't work. |
Well, I've taken your uploaded file, corrected the "languagename" by just adding "Silent" to the end (as per my instructions) and then zipped it up with the correct folder structure. It is now selectable and works perfectly.
So the simple set of instructions work fine if followed correctly, and of course no errors are created when creating the zip file.
I think that in future you should check to make sure that you are following instructions correctly before just complaining time after time that they don't work, after all, I have no obligation whatsoever to provide you with any instructions at all.
linknet |
Posted: Sun Mar 22, 2009 10:30 am Post subject: |
Added Version 6.0.17
- Added a "Hide" button for the Pop-Up Info Panel on the "Plan on Map" screen. This button overlays the "Fit Route to Screen" button whilst the Pop-Up Info Panel is active. Tapping it hides the Pop-Up Info Panel making it easier to set destinations and waypoints without having to turn the Pop-Up Info Panel off completely. To restore the Pop-Up Info Panel just tap the button again whilst it is active. The hidden state is retained until iGO8 is restarted. To just close the Pop-Up Info Panel normally tap the top "Address" section of the panel as before.
- Added access to the "Itinerary" screen via "Tap and Hold" on the "Route" button on the "Plan on Map" screen.
- Added access to the "Itinerary" screen via "Tap and Hold" on the "First Route Event" icon on the "Map" screen.
linknet |
Posted: Mon Mar 23, 2009 4:04 pm Post subject: |
Added Version 6.0.18
- Modified the new "Hide" button for the Pop-Up Info Panel on the "Plan on Map" screen to reflect the current hidden state, which is now remembered after iGO8 is restarted.
- Added a "Hide" button for the Pop-Up Info Panel on the "Plan on Map" screen. This button overlays the "Fit Route to Screen" button whilst the Pop-Up Info Panel is active. Tapping it hides the Pop-Up Info Panel making it easier to set destinations and waypoints without having to turn the Pop-Up Info Panel off completely. To restore the Pop-Up Info Panel just tap the button again whilst it is active. The hidden state is remembered when iGO8 is restarted. To just close the Pop-Up Info Panel normally tap the top "Address" section of the panel as before.
linknet |
