Chocki Occasional Visitor
Posted: Fri Jun 18, 2004 6:06 pm Post subject: |
Damn, and I thought I had it sussed, the bad news is that TT3 froze on me late this afternoon when I turned the PDA back on.
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Fri Jun 18, 2004 6:58 pm Post subject: |
chocki i think you have an sd card issue and may need to format your card then reinstall the maps
chocki could you please put you location in your profile as this could affect any reponses give if we know which pda and gps your useing thios also helps
thanks _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
jedstagg Occasional Visitor
Joined: 22/05/2003 14:04:18 Posts: 31 Location: Brighton, UK
Posted: Fri Jun 18, 2004 7:50 pm Post subject: |
I also have this problems and regularly have to pull over and exit, restart, exit restart, disconnect power, reconnect power, softreset x3 etc etc until the damn thing works again
I cannot find a cure at all. Anyone else close to a solution yet?! |
chris24 Occasional Visitor
Joined: Jun 16, 2004 Posts: 3 Location: Chichester, West Sussex
Posted: Fri Jun 18, 2004 8:05 pm Post subject: |
The problem seems to be with the TT3 software as I had no issues at all with TT2 and I am still using the same GPS, PSU, etc.
On the Axim X3, TT3 starts ok but after what appears to be a random time, the application just locks up and a soft reboot is the only way out. This then works fine for another short period of time. Loading back TT2 everything works continuously just fine.
On the 16th June, I logged an e-mail with TomTom over this issue but so far it just has a status 'unresolved'.
Should I send another e-mail to TomTom with a link to this page? |
Posted: Fri Jun 18, 2004 8:11 pm Post subject: |
the processor on the x3 can be scaled down to conserve power maybe that could be you problem but still think its a sd card prob
it might be an idea to check the processor speed incase its been scales back by initiating the power save fetures _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Fri Jun 18, 2004 8:13 pm Post subject: |
OK, I'm using a Toshiba E750 Bluetooth model with the TomTom bluetooth GPS and TomTom Navigator 3.02 software, I did a complete cold reset and formated both SD cards I own, then did a fresh Install to the PDA and onto the cards.
I am in the UK and travel all over it since I am a service engineer, but my home location is Wolverhampton.
Current maps are on an Integral 256MB SD card. |
Posted: Fri Jun 18, 2004 8:30 pm Post subject: |
have you tryed an rom upgrade from the tosheaba web site
theres few up grade there for the bt stack bios and sd card reader maybe if you try some of those (url here) _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Tue Jun 29, 2004 6:24 pm Post subject: |
I have received the following response to an email sent to TomTom Support. I have not yet tried the suggested fix.
________________
TomTom Support Response received 29.06.04:
I Would suggest that you download and install the latest update 3.03
If you have Traffic installed DO NOT INSTALL this, instead install the 3.04T
www.tomtom.com Support/FAQs Update June 2004 - TomTom Navigator 3.03 - Pocket PC
Perform a soft reset of the PDA.Go to Start/Settings REMOVE PROGRAMS and REMOVE the TOMTOM GPS'
then make another soft reset and install the 3.03
With best regards,
The TomTom Customer Support Team
___________________________________
Original email to TomTom Support:
Hi Folks,
I purchased TomTom2 January last and a Dell Axim X3 and Haicom 420S. All has worked perfectly until I upgraded TomTom to version 3.
Although the system works, the Axim pocket pc locks up after about an hour of running TomTom3. I can only reset the device to get it to work again.
If I put back TomTom2, everything works fine again with no problems.
I have checked your FAQs and this does not appear to be a regular issue. Any suggestions please?
Many thanks |
spewy Occasional Visitor
Joined: 21/05/2003 23:13:02 Posts: 9 Location: United Kingdom
Posted: Tue Jun 29, 2004 7:15 pm Post subject: I had the same problem |
Had the same problem with my 3970 and also a 3950. Solved the problem by installing GPS driver 2.08 and since then I haven't had one screen freeze. The Ipaqs run pocket pc 2002.
Hope this helps
Matt |
PhilJ Occasional Visitor
![](modules/Forums/images/avatars/Sphere_animated_small_neg2.gif)
Posted: Thu Jul 01, 2004 12:52 pm Post subject: TT3 screen freeze |
Since upgrading to TT3.03 and TT GPS3.03 I now have screen freeze after about 30 minutes with my Navman BT and XDAII (drawing in-car power), making in-car satnav virtually impossible. I have a 512MB Japanese SD card which seems to work faultlessly.
Has any one else experienced a similar problem or can offer a solution?
Thanks in anticipation,
Phil |
InspectorGadget Occasional Visitor
![](modules/Forums/images/avatars/techno_eye.jpg)
Joined: Jul 02, 2004 Posts: 1 Location: South West England
Posted: Fri Jul 02, 2004 10:05 pm Post subject: Re: I had the same problem |
spewy wrote: | Had the same problem with my 3970 and also a 3950. Solved the problem by installing GPS driver 2.08 and since then I haven't had one screen freeze. The Ipaqs run pocket pc 2002. |
Thanks Matt
I'm using an iPAQ 3850 running Pocket PC 2002 with TT3 which I upgraded from TT2 just before going away on holiday. It was an absolute pain with the screen freezing. Updated to 3.03 when I got home, but still the problem was there. On your suggestion have installed the 2.07 GPS driver, which I found on this site, and so far so good, no more screen freezes.
Thanks again.
ian :D |
