bkilham Lifetime Member
Posted: Thu Mar 12, 2009 10:44 pm Post subject: App 8.320 - Should I change? |
Following the excellent advice on these forums I changed my 720 to App 8.320 to cure the problems I had. Is it now safe to go back to the standard application so that I can get the updates for it or should I leave well alone. I backed up using windows explorer before changing, can I just delete everything on the 720 and then copy the back up to it? |
Posted: Thu Mar 12, 2009 10:50 pm Post subject: |
I have been running with the 8,302 software release since it was made available and have had no real issues with it, the new application is considerably better than the previous two releases.
If you want to get Home support back on the device then I guess putting the 8,302 release on your device will be fine - Mike |
Posted: Fri Mar 13, 2009 7:13 am Post subject: |
Thanks Mike.
So if I use windows explorer to delete every file on 720 then copy and paste my last backup, I can then download 8.302? |
Posted: Fri Mar 13, 2009 8:44 am Post subject: |
Couple the unit to the PC and look at the contents of the TomTom via Windows Explorer, delete all the files in the root of the drive, DO NOT touch any of the folders or files within folders, just the loose files in the root.
Now start Home and it will connect to the device, download the 8,302 update and install it.
Or
Just click Here then install the update in the same way you put the 8,320 on last time - Mike |
jimbo_hippo Frequent Visitor
Posted: Fri Mar 13, 2009 10:34 am Post subject: |
The only issues we seem to have found is that (certainly on the 720s) if you run on battery and use TTS computer voices the voices can cough then dissapear when your battery drops to around 50%.
Otherwise on power cable, all seems to be OK. Still room for improvement on a few of the features but nothng you didn't have in 8.320. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
Posted: Fri Mar 13, 2009 7:35 pm Post subject: |
Thanks again Mike.
I used the second method you suggested and downloaded 8.302 direct and installed with WinRAR.
I have not used it on the road yet but can now operate it via HOME.
Only thing I have found so far is that when I click on "Show Contents" it says that I have got 8.301 not 8.302. (It also said 8.301 when I had 8.320)
Brian. |
Posted: Fri Mar 13, 2009 8:57 pm Post subject: |
When you click "Show contents" is that using Home that is reporting the wrong version? - if so simply ignore it as it is wrong.
To establish the true version the device is using start the TomTom with no PC connection and tap the sat strength meter followed by the version box, the resultant screen will show you the details of the Navcore version (software) and your currently active map as well as other details - Mike |
