Mojo Regular Visitor
dhn Frequent Visitor
Posted: Fri Feb 27, 2009 11:13 pm Post subject: |
It appears as if it may be a corrupt download. If you are connected via wireless router/modem, you may wish to use a direct connection for the dl.
Try the download again. _________________ David |
Andy_P Pocket GPS Moderator
Posted: Sat Feb 28, 2009 2:02 am Post subject: |
Possibly everyone is trying to download new maps tonight and their servers are falling over again? |
Posted: Sat Feb 28, 2009 10:03 am Post subject: |
I'm not sure, I tried downloading twice last night and the same thing happened. The map actually downloaded successfully (part 1 of the whole process). The error comes up about 1/4 - 1/3 way thru the actual installation process (part 2 on TT Home).
They are the Western and CE maps I am downloading. I can open the .zip file and see all the map files ok...
I posted a question to TT support but guess I will have to wait a few days at least before a reply. Anyone else having such issues?
Update: I've just run a test check of both downloaded W&CE zip files and they both mark the crpoi.dat file as failed. _________________ TTG 720
Navcore 8.351
Western and Central Europe 2Gb v845.2645
Home 2.7.3.1894 |
gduvl Occasional Visitor
Posted: Sat Feb 28, 2009 3:25 pm Post subject: |
I've exactly the same fault...... i.e. crpoi.dat shows as corrupt. D/L map many times but always with the same fault. crpoi.dat file size shows as 47,164,022. Can anybody confirm if this is the correct size please? Mojo - is the file size the same as you have? Anyone know of a fix/workarround? |
Posted: Sat Feb 28, 2009 6:42 pm Post subject: |
gduvl wrote: | I've exactly the same fault...... i.e. crpoi.dat shows as corrupt. D/L map many times but always with the same fault. crpoi.dat file size shows as 47,164,022. Can anybody confirm if this is the correct size please? Mojo - is the file size the same as you have? Anyone know of a fix/workarround? |
Glad it's not just me! Yes, the crpoi.dat file I have is the same size. Anyone else having the same problem for Western & CE v8.25 maps? Or are other maps having the same problem? Maybe a faulty zip on the TT servers? _________________ TTG 720
Navcore 8.351
Home 2.7.3.1894 |
Posted: Sat Feb 28, 2009 8:56 pm Post subject: |
Mojo I've managed to get the map installed by a bit of jiggery pokery! All appears ok so far so if you do the same it's at your own risk. Backup first etc.
Open the W&CE 2gb zip and highlight crpoi.dat. Right click and choose delete. NB it takes a while to achieve. Then extract as normal.
My sd card is only 2gb so I deleted my old v815 map via Home to ensure room. It backs up the old map prior to removal.
Via Home use the Add Maps function and it should show W&CE as being located on your computer...click Add.
That should do it.
Best of luck.
duvl
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Mon Mar 02, 2009 11:07 am Post subject: |
Hi Mojo / gduvl
I’m glad that I am not the only user suffering from the same error. Mojo, can you let us know how things work out for you on this topic? By the time I hear from Tomtom support it will be near Christmas. _________________ Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G |
Posted: Mon Mar 02, 2009 12:31 pm Post subject: |
I logged a call with TT support and got a "reply" below... Has anyone else managed to get the W&CE c8.25 maps installed successfully? I haven't tried gduvl hack of getting it on. I assume he used the v8.15 crpoi.dat file instead of the faulty v8.25 version?
Thank you for your query regarding xxxx
We currently cannot offer you an immediate suitable solution for this problem. We have sent your question to our 2nd line technical department.
We hope to have an answer for you as soon as possible, please bear with us while we find a solution for your query.
With Best Regards
TomTom Customer Support Team
=========== _________________ TTG 720
Navcore 8.351
Home 2.7.3.1894 |
Posted: Mon Mar 02, 2009 4:13 pm Post subject: |
Hi Mojo
When one lands up with the Tomtom 2nd line technical department things look bleak indeed. I know, I’ve been there. I think our only chance lies with this forum. I have gone carefully through your \error data and it is exactly the same as mine. So we both have the same problem.
By the way gduvl my crpoi.dat = 47,164,022 and is the same as yours. However, I see no mention of it being corrupt. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Mon Mar 02, 2009 4:19 pm Post subject: |
I'm pretty sure you do but can you check anyway: In Add Programs in Control Panel, do you have dot net Framework installed? If not, you can get it here.
I've seen more than one user not having it installed and Home just crashed. _________________ David
Posted: Mon Mar 02, 2009 4:25 pm Post subject: |
Yes I do have .net framework installed.
Damn! However, I have to go now but will resume in my quest for a solution later tonight. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Mon Mar 02, 2009 4:30 pm Post subject: |
Trevor have you opened W&CE and instead of extracting run test? It's when test is run that it shows crpoi.dat as corrupt. |
Posted: Mon Mar 02, 2009 10:11 pm Post subject: |
I might call them tomorrow and see if talking to them is of any help. However I don't hold out much hope. I just want to confirm on this forum if anyone has downloaded and installed W&CE v825 maps yet? So far we have three people saying it's failed and no one saying it downloaded and installed successfully (short of fudging it) or are TT admitting there is a problem with the W&CE v825 maps from their reply above? _________________ TTG 720
Navcore 8.351
Home 2.7.3.1894 |
Posted: Mon Mar 02, 2009 11:19 pm Post subject: |
Hi gduvl
Yes, you are quite correct about the crpoi.dat it is corrupt. I tested all the other files and they appear to be ok. So, I have read your ‘work around’, does it work ok?
The bit that puzzles me is by deleting the dat file (size 47,164,022) I cant see how it can work. Can you explain please.
Mojo, if you do manage to ring Tomtom can you let us know the result please? At the moment we both appear to be stuck. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
