Pocket GPS World :: View topic - GPS fix won't update
Jeremy69
PostPosted: Fri Feb 20, 2009 7:27 pm    Post subject: GPS fix won't update Reply with quote
My 520T has updated without problem for some time. Last week the GPSFix update stopped working and gave an error message. The message starts as below. All the other updates Map Share, Cameras etc work without problem. Anyone got any ideas off what I might do. tom Tom support haven't been unduly helpful.
ERROR: [Exception... "Component returned failure code: 0x80520015 (NS_ERROR_FILE_ACCESS_DENIED) [nsIFile.remove]"
AndyVaughan
PostPosted: Fri Feb 20, 2009 8:13 pm    Post subject: Re: GPS fix won't update Reply with quote
Try deleting all of the ephemeris downloads in your HOME downloads folder and also deleting the contents of the ephem folder on the device.
A clear flash and pin reset might not go amiss as well.
Andy
Jeremy69
PostPosted: Sat Feb 21, 2009 11:52 am    Post subject: GPSFix Reply with quote
Thanks for the suggestions. I have tried them but to no effect. The saem error message remains. Has anyone a further idea?
Pocketgps
PostPosted: Sat Feb 21, 2009 12:23 pm    Post subject: Re: GPSFix Reply with quote
Have you got a FULL backup of your unit. You could try saving your current set-up with a FULL backup then install the last good one and see what happens.
Don't use HOME as this will over-write the last one unless you change its name.
Always best to use Explorer and use a new name each time you backup.
PostPosted: Sat Feb 21, 2009 12:24 pm    Post subject: Reply with quote
How often do you use the device? - if you use it every few days there is no point in downloading the data via Home, the device gets all the information it needs while its in use. I haven't bothered with the qGPS for quite some time now as I find it unnecessary and I still get very respectable times for achieving a GPS position fix.
Try using the device without it and I bet you won't notice the difference, if this is the case why try fixing something that doesn't work when its not required? - Mike
PostPosted: Sat Feb 21, 2009 12:46 pm    Post subject: Reply with quote
Just to back up what Mike says - I haven't downloaded GPSFix since February last year. By the time I get myself ready to pull out of my drive, I've always got a fix (on all three of my devices!).
AndyVaughan
PostPosted: Sun Feb 22, 2009 10:14 am    Post subject: Reply with quote
Same here - I don't bother with it.
Make sure you ephem folder on the device is empty though .....
Andy
Trevor1234
PostPosted: Sun Feb 22, 2009 12:07 pm    Post subject: Reply with quote
Hi DennisN
No, I don’t bother with the GPS Fix, no need. In fact I don’t bother with ‘Home’ either except If there is a map I may wish to download.
However, If I did try to download the GPS Fix and came up against the same snag as Jeremy69 I too would be puzzled. Not only puzzled, I would want to find the cause too.
Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G
PostPosted: Sun Feb 22, 2009 4:53 pm    Post subject: Reply with quote
Sounds a bit like the condemned man helping Albert Pierrepoint fix a problem with the trapdoor. Twisted Evil
alanji
PostPosted: Sun Feb 22, 2009 7:15 pm    Post subject: Reply with quote
That'll be after you wash the car, pour a cup of tea and have a slice of toast, eh? Laughing
HOME has obviously taken notice as it no longer offers me a GPSfix update.
Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner
PostPosted: Sun Feb 22, 2009 7:19 pm    Post subject: Reply with quote
I haven't got a car. (But I sometimes carry three devices on a string round my neck and run up the road howling Brrrrm, Brrrrm, Beep, Beep!!)
alanji
PostPosted: Sun Feb 22, 2009 7:27 pm    Post subject: Reply with quote
Nice one, Dennis. But it does make me wonder where you plug in the charger Surprised
Alan
Dell Axim & TT3
Jeremy69
PostPosted: Sun Feb 22, 2009 11:50 pm    Post subject: Reply with quote
Thank you all. Don't bother sounds a good solution especially as there are no il effects thus far but I am curious as to why it has started to happen.
Trevor1234
PostPosted: Mon Feb 23, 2009 11:59 am    Post subject: Reply with quote
Hi DennisN
Stop hanging about and get on with your work.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
PostPosted: Mon Feb 23, 2009 12:06 pm    Post subject: Reply with quote
Trevor1234 wrote:
Hi DennisN
I haven't got any work, nobody's called me. Unless you're thinking about the pot of paint and the filler stuff sitting on the landing. Evil or Very Mad I'm not good (therefore not exactly early starter) at doing It!
22.063 (19 Jun 24)
