fr0d0 Occasional Visitor
Posted: Tue Feb 17, 2009 11:49 pm Post subject: |
ok will do
currently 2nd turn settings on with both at 300m |
Posted: Wed Feb 18, 2009 8:06 pm Post subject: |
hmm - turning off 2nd route event made the ghost 2nd route backgound disappear and I couldn't then recreate it. I've seen it a few times now. I'll keep an eye on it and see if I can spot what triggers it. |
linknet Frequent Visitor
Posted: Wed Feb 18, 2009 8:40 pm Post subject: |
fr0d0 wrote: | hmm - turning off 2nd route event made the ghost 2nd route backgound disappear and I couldn't then recreate it. I've seen it a few times now. I'll keep an eye on it and see if I can spot what triggers it. |
I had previously suspected a faulty speedcam database file.
If it appears again try tapping it.
If you get a click then tap it again and if that makes it disappear then it's a speedcam problem.
If the Itinerary opens then it's a 2nd turn problem.
Regards
linknet |
Posted: Wed Feb 18, 2009 11:50 pm Post subject: |
ok will do
(I think I tried tapping it and nothing happened) |
Posted: Thu Feb 19, 2009 3:18 pm Post subject: |
fr0d0 wrote: | ok will do
Check your PM's for a possible fix.
linknet |
mihok Occasional Visitor
![](modules/Forums/images/avatars/84806192499e0731948ca.jpg)
Posted: Fri Feb 20, 2009 2:16 am Post subject: |
Hi!
I have a similar problem on TIBO XROAD A4050
coul'd you help me to, please?
many thanx!
sorry for my English
Patrick2008 wrote: | Hello guys,
I can't get the Ultra skin working.
If i select it and iGo will restart i get an error:
FFUIERROR: Unknown object indentifier
Indentifier = [vGetUpdates]
Script "st_Start_init"
command 45
Can someone help me because the ultra skin is the only skin for me. I refuse to use others. And default is nothing compared with the Ultra skin. |
Posted: Fri Feb 20, 2009 8:58 am Post subject: |
mihok wrote: | I have a similar problem on TIBO XROAD A4050
could you help me too, please? |
You must be using the wrong data.zip for the version of iGO8 that you are using. With the correct data.zip you will not get that error.
linknet |
Posted: Fri Feb 20, 2009 9:42 am Post subject: |
of course
but I have only this one
how can I get an other one?
linknet wrote: | mihok wrote: | I have a similar problem on TIBO XROAD A4050
linknet |
Posted: Fri Feb 20, 2009 9:51 am Post subject: |
mihok wrote: | of course
but I have only this one:(
From the same place that you purchased iGO8
linknet |
Posted: Fri Feb 20, 2009 10:44 am Post subject: |
how can I decide which one is working?
many thanx!
linknet wrote: | mihok wrote: | of course
linknet |
Posted: Fri Feb 20, 2009 11:09 am Post subject: |
mihok wrote: | how can I decide which one is working?
many thanx!
I have listed the versions that are compatible.
linknet |
Dusha Occasional Visitor
Posted: Fri Feb 20, 2009 11:17 am Post subject: AMIGO |
Ahmmm..
look here: http://navngo.com/pages/global/eng/cebit_2009
It looks like that some new product called IGO Amigo is due to be released later this year...
New skins again?
R3 upgrade is still not released for existing R1 customers and they are already talking about some mysterious Amigo....
http://www.i-go.com/amigo/ |
Posted: Fri Feb 20, 2009 11:25 am Post subject: |
I have this version: iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
what you thing, why did I ask you?
linknet wrote: | mihok wrote: | how can I decide which one is working?
many thanx!
linknet |
Posted: Fri Feb 20, 2009 11:32 am Post subject: |
mihok wrote: | I have this version: iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
Then it's the same answer:
Where did you purchase the iGO8 software ?
linknet |
