Pocket GPS World :: View topic - O2 Serra/HTC Touch Pro
onemanband
PostPosted: Thu Feb 19, 2009 9:13 pm    Post subject: O2 Serra/HTC Touch Pro Reply with quote
Is anyone out there using CoPilot 7 with the O2 Serra (HTC Touch Pro)?
I am considering upgrading to the O2 Serra, but have read of problems with the satellite log on.
As the sat nav is an important part of my requirements, I would appreciate any comments/experiences etc., of this combination.
This phone seems a good choice, as it suits in all other aspects.
Cheers...............Brian
alix776
PostPosted: Thu Feb 19, 2009 10:47 pm    Post subject: Reply with quote
i use copilot with this device and havent had any problems with TTF's at all
device Lumia 950 xl
onemanband
PostPosted: Fri Feb 20, 2009 7:28 am    Post subject: Reply with quote
Thanks Alix776.......fast reply as usual!!
Sorry to appear a bit dim, but what are "TTF's"?
You would endorse this combination then?
Cheers ..........Brian.
alix776
PostPosted: Fri Feb 20, 2009 8:30 am    Post subject: Reply with quote
personally its what i use as my main navigation app
ttf time to fist fix
device Lumia 950 xl
reteb
PostPosted: Fri Feb 20, 2009 11:47 am    Post subject: Reply with quote
Maybe 'Time to First Fix'?
(unless it doesn't connect, of course. Then you may be right!))
onemanband
PostPosted: Sun Feb 22, 2009 11:37 am    Post subject: Reply with quote
I've had the phone (O2 Serra) for just under a week now and there are definetely issues regarding the satellite fix times, sometimes taking ten minutes or more, not much use when I want to be on the road quckly.
This, combined with one or two other features I didn't like have pusuaded me to return the phone and revert back to my good old reliable XDAOrbit2!
To quote Joni Mitchell......"you don't know what you've got 'till it's gone" Laughing
Brian.
alix776
PostPosted: Sun Feb 22, 2009 1:16 pm    Post subject: Reply with quote
are you driving while trying to get a gps fix this would be normal if this is tha case mine fires up in 2minutes try putting gps today on a set it for 30 minutes this should help the fix times
device Lumia 950 xl
alix776
PostPosted: Sun Feb 22, 2009 1:34 pm    Post subject: Reply with quote
device Lumia 950 xl
sleepyste
PostPosted: Sat Feb 28, 2009 1:06 pm    Post subject: Reply with quote
There is a 'GPS Software Update' available on the O2 website which will install the missing QuickGPS application and greatly improves the time to acquire a GPS fix. I havent had any problems using CoPilot since installing the update and usually have a GPS fix before setting off now!
Find it here (you need your Serra's S/N) http://www.my-xda.com/software_updates.jsp
alix776
PostPosted: Sun Mar 01, 2009 7:22 pm    Post subject: Reply with quote
using something like gps today (use the standalone app which is free) will help also personally i would use quickfix gps as it can lead to incorrect positining as it downloads the data for sat 32 which most application either cant use or it throws the positioning out
device Lumia 950 xl
samsul
PostPosted: Mon Mar 02, 2009 4:39 pm    Post subject: Reply with quote
I too find Copilot 7 takes long time to get GPS fix, once it took about 30 mins. Now I start Garmin first, which ALWAYS gets a gps fix in less in 30 secs then load Copilot.
22.062 (12 Jun 24)
