4ndynorfolk Regular Visitor
Posted: Sun Feb 15, 2009 3:46 pm Post subject: |
muggerb wrote: | Even though I'm registered, everytime I try to log onto Route Share I get bounced back to the initial Register your Active 10 page!
Route Planner works great though - except height info doesn't get transferred. |
I just had a play on route Planner and had to log in as expected. When I then took a look at Route Share, in the same IE session, no log in was required. Possibly a cookie driven feature.
If that does not work try deleting the Satmap cookies and then try again. |
philpugh Lifetime Member
Posted: Sun Feb 15, 2009 8:43 pm Post subject: |
Nice software.
I will feedback to Satmap, but with my short playing with it setting up routes for 'the lads' Spring weekend Lake District walking I would like to see a "Save As.." feature. This would allow me to have different variations on a route (e.g. valley or ridge section depending on weather) without having to plot all the waypoints again. It may be there but it's not obvious. I've handled this by doing a main route and alternative sections as separate routes. Not ideal - but workable.
Also the works area isn't as large as I would like - but this is nit-picking a beta release _________________ Phil |
Posted: Mon Feb 16, 2009 2:44 pm Post subject: |
From the postings in this thread, it seems that most or all those using the beta have had to re-register.
Does anyone know if that is because the beta is on a different server, with the registation data not copied across?
If the database has been somehow lost, it cold be interesting when they introduce a charge for those not registered. |
terry8 Occasional Visitor
Posted: Mon Feb 16, 2009 4:54 pm Post subject: |
I have been attempting to download a route directly from the new route planner to my Active 10 using the USB lead, but I am continuously being directed to Memory Map, then having to convert to GPX file transfer this to Satsync, and from there importing into my Active 10. This seems like a drawn out way plus using MM you lose Elevation details. I have contacted Satmap regarding this and the answer I got was "This is down to the fact that you probably have .gpx files default application set to Memory Map. This is a setting within your Operating System, when you download you should be able to save rather then open the file". I am afraid I did not quite follow this.Can anyone throw any light onto this?
Terry |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Mon Feb 16, 2009 5:17 pm Post subject: |
I have now managed to register. According to Satmap Quote: | There was a problem with the registrations database, your unit has not been previously registered, and I am sorry for any concern caused |
So there does seem to have been some trouble with their registration database, hopefully now resolved. _________________ David
(Navigon 70 Live, Nuvi 360) |
goon525 Regular Visitor
Posted: Mon Feb 16, 2009 5:28 pm Post subject: |
terry8 wrote: | I have contacted Satmap regarding this and the answer I got was "This is down to the fact that you probably have .gpx files default application set to Memory Map. This is a setting within your Operating System, when you download you should be able to save rather then open the file". I am afraid I did not quite follow this.Can anyone throw any light onto this?
Terry |
Terry, you don't say what operating system you're using, but in Vista you would go to Control Panel/Default Programs/Set Associations, find .gpx and take it from there. It's a while since I've done this in XP but it will be something similar. |
daveweth Occasional Visitor
Posted: Mon Feb 16, 2009 5:53 pm Post subject: |
In XP go to Control Panel-Folder Options-File Types then look for GPX in the extensions column. |
Posted: Mon Feb 16, 2009 7:09 pm Post subject: |
Thanks goon525........Sorry I should have mentioned it was Vista. I have followed your directions and have found the GPX file but I am not too sure what File/Programme to associate it with, please excuse my stupidity if this is obvious.
Terry |
Posted: Mon Feb 16, 2009 7:17 pm Post subject: |
Personally, I associate Notepad with mine, then I can peek inside and edit the file if required.
I don't think Satsync is an option. |
Posted: Mon Feb 16, 2009 9:21 pm Post subject: |
terry8 wrote: | I have been attempting to download a route directly from the new route planner to my Active 10 using the USB lead, but I am continuously being directed to Memory Map, then having to convert to GPX file transfer this to Satsync, and from there importing into my Active 10. This seems like a drawn out way plus using MM you lose Elevation details. I have contacted Satmap regarding this and the answer I got was "This is down to the fact that you probably have .gpx files default application set to Memory Map. This is a setting within your Operating System, when you download you should be able to save rather then open the file". I am afraid I did not quite follow this.Can anyone throw any light onto this?
Terry |
When you use the download GPX option from the Routplanner you should be prompted if you want to Open or Save the file. Simply save the file to a folder then use SatSync to Import the route into your Active 10 _________________ Phil |
johno99 Regular Visitor
Posted: Mon Feb 16, 2009 9:57 pm Post subject: |
Ive tried every combination of serial number to log on.No luck. Do you type in the hyphens as well? Mind you Ive tried that as well!
John |
Posted: Mon Feb 16, 2009 10:12 pm Post subject: |
The serial number is under the battery housing you will see a bar code under which is the CE mark followed by the part number "SM-ACT-10-V1UNT" below this part number is another line of text which is the device serial number, it is this you need to use for registration, there are no hyphens in the device serial number AFAIK - Mike |
Posted: Mon Feb 16, 2009 10:25 pm Post subject: |
And remember to use UPPER case for 'ACT10UK...' _________________ David
robs1972 Frequent Visitor
Posted: Mon Feb 16, 2009 10:35 pm Post subject: |
BigPerk wrote: | And remember to use UPPER case for 'ACT10UK...' |
Doesn't appear to be case sensitive...used it the other day in lower case without a problem and just tried it again in lower and it's still ok. _________________ I like mapping, I like mapping, I like mapping and I like to map! |
marty-w Occasional Visitor
Posted: Mon Feb 16, 2009 11:16 pm Post subject: |
I have just tried to upload a gpx file from the satmap to the route planner and it said the file was too big??
It said there was a maximum of 100kb which seems incredibly small and I don't know of any way of reducing the gpx file created by the satmap device.
Has anyone else encountered this problem?
-martin- |
