Pocket GPS World :: View topic - TomTom Custom Voice Alert Download Page Added
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 15, 16, 17  Next
jackdark
PostPosted: Sun Dec 28, 2008 11:10 pm    Post subject: JSUT WANTED WARNING VOICES - NO RUN AROUND Reply with quote
WORST PAGE EVER, I JSUT WANTED VOICES FOR WARNING OF CAMERAS AND IT SEND YOU IN CIRCLES. THE OTHER PAGE JSUT OPENS AN EXAMPLE ON PC AND PLAYS WITH NO SAVE OPTION TO BE ABLE TO TRANSFER IT INTO MY TOMTOM. Crying or Very sad
PaulB2005
PostPosted: Sun Dec 28, 2008 11:17 pm    Post subject: Reply with quote
You click on the Click Here under the Voice Name and then click on the database type you are using on the following page. Then the file downloads.
Many others have succeeded. In fact you have just said the following here
the one on the site does not work and i am positive i posted it correctly in my voice files
So did you get it downloaded or not?
PostPosted: Sun Dec 28, 2008 11:19 pm    Post subject: Reply with quote
Click the 'CLICK HERE' link for your chosen voice then click the button for your the database you have installed. All works fine as can be seen by the many members here using it!
However as you aren't a subscriber I'd have to ask where you got the database? As you haven't paid for it you've a bit of a cheek asking for help in using it.
PostPosted: Sun Dec 28, 2008 11:32 pm    Post subject: Reply with quote
First, please calm down and stop shouting.
Hundreds of other people have installed the voices without problems, so let's try to find out what you are doing wrong....
Without anything else to go on, lets assume you have a TomTom and are going to this page:
http://www.pocketgpsworld.com/speed-camera-alerts-tomtom.php
Taking one at random, lets go to "Text to Speech - Simon".
If I click on the "Play sample" link on the left it downloads and then plays an example of the voice so I can hear what to expect. Your browser may behave differently.
If I then click on the "Click Here" link it takes me to the downloads page for the three available versions for this voice - voice only, or with two different bleeps at the front of the voice.
As this voice set only has files for the speed-zoned database version, there are three buttons labelled "Speedzoned" on the right.
Clicking any one of these downloads the files as a "zipped" archive file (as is common practice on the web to make downloads smaller and faster).
All of those downloads will extract the relevant files with a simple right click. Following the install intructions you are then told to copy those files into the same named map folder as you put the camera database files themselves.
How is your experience different. Maybe there is an instruction that we could make clearer?
PostPosted: Sun Dec 28, 2008 11:35 pm    Post subject: Reply with quote
Oops, took too long in replying....
Maybe he has the database from a previous existence?
Suspicions...)
letmeboogey
PostPosted: Wed Feb 04, 2009 7:15 pm    Post subject: Voice speed alerts - Garmin 765 Reply with quote
Hi All
I have downloaded the latest speed camera database, and chose the uk Speed zoned - complete option. I then download the voice speed alert for speed zone option. This works fine but i was curious when i clicked here underneath the photos of those that provided the voices i could only see one option and that was speed zone. I cannot see the options to download other variants such as consolidated for those that use that version of speed camera alerts as i understand that these voice alerts need to be the same as the speed camera database type.
Also do the voices alerts get updated and can we continue to same the same ones ?
Please help i was just curious.
Regards
Letmeboogey
PostPosted: Wed Feb 04, 2009 7:34 pm    Post subject: Re: Voice speed alerts - Garmin 765 Reply with quote
Some voices support the full range of database types, some only one or two.
The voices do not need to be updated but we regularly add additional voices and update existing voices to support more database types where we are able.
absolutereality
PostPosted: Sun Feb 15, 2009 7:40 pm    Post subject: Reply with quote
I have a 520.
I installed the spoken sound effects but am not too keen on them, problem is that I can not revert back to the old sounds!!
Can you point me in the right direction please!
GerryC
PostPosted: Sun Feb 15, 2009 8:32 pm    Post subject: Reply with quote
absolutereality wrote:
I have a 520.
If you copied the voice files into your map folder, just delete them (make a backup first) and go back into the "warn when near" function to get the original options back.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
absolutereality
PostPosted: Sun Feb 15, 2009 8:48 pm    Post subject: Reply with quote
Thanks for that. I didn't think it'd be that straight forward!
PostPosted: Mon Feb 16, 2009 10:09 am    Post subject: Reply with quote
I have a 520.
Which voice did you try? There are a number of alternative voices and they're all quite different?
absolutereality
PostPosted: Tue Feb 17, 2009 12:02 pm    Post subject: Reply with quote
I installed the Vicki Archer voice but realised I just prefer a warning sound instead.
mrfreeze
PostPosted: Thu Apr 23, 2009 10:22 pm    Post subject: Help needed with voice alert. Reply with quote
Hi Guys,
So i just subscribed to the cams.
Downloaded UK speed zoned complete.
Then found the Kate voice file (ogg) from on here, the one without chime option.
All copied to my device (Go920) and then went through set up.
So my problem, when i get to the warn when near POI, i choose the relevant POI, set the distance then select "sound effect" and it gives me all the default options....Bell 1 Beep 1 etc, which am i supposed to chose to get the custom ogg files to work?
Neil
FYI, its the latest map 825, latest app 8.302 and yes the cam files and ogg files are in the WE map folder.
Go 720 v8.351 GPS v1.20 Boot 5.5120
Kate v710 UK & ROI v850.2781
Go 920 v8.351 GPS v1.20 Boot 5.5120
PostPosted: Thu Apr 23, 2009 10:25 pm    Post subject: Reply with quote
If you have installed as per our recommended method you wouldn't see those options. It would just say 'Is this the sound you want?'.
The installation instructions are at the bottom of the main page here.
mrfreeze
PostPosted: Thu Apr 23, 2009 10:36 pm    Post subject: Reply with quote
From what i can see i have followed all the instructions.
Here is a cap from my map file:-
Clearly shows POI's and ogg files in same folder.
Still it asks me for a sound after i choose "sound effect"
Any idea's???
Page 12 of 17
23.015 (29 Jan 25)
