Pocket GPS World :: View topic - Distance & Time
Distance & Time
arkiboys
PostPosted: Fri Feb 13, 2009 10:52 am    Post subject: Distance & Time Reply with quote
Using a Garmin nuvi 250, how do I find the milage and time it takes to get to the destination p lease?
greg_m
PostPosted: Fri Feb 13, 2009 12:15 pm    Post subject: Reply with quote
i don't have my nuvi with me, but as i remember tap on the 3d map, it will show you a route turn-by-turn. then on this screen touch the 'show map' on the bottom and you will see distance and time to get to a destination (as well as 2d map of a journey).
arkiboys
PostPosted: Fri Feb 13, 2009 12:49 pm    Post subject: d & t Reply with quote
No, that is not it.
PaulB2005
PostPosted: Fri Feb 13, 2009 1:27 pm    Post subject: Reply with quote
Usually (although it can change from model to model) you get to the the 3d map and then tap the bottom right corner where it says how far to next turn. It'll bring up details of that turn, then use the down arrow to scroll to the end of the instructions and it'll tell you the total distance and time.
arkiboys
PostPosted: Fri Feb 13, 2009 1:41 pm    Post subject: dt Reply with quote
I remember seeing the turn by turn list once. Can not find it now but will try again...
Is there somewhere where it sums up the time and distance for all these turns and gives the figures as the total distance and time to get from A to B?
PostPosted: Fri Feb 13, 2009 2:02 pm    Post subject: Re: dt Reply with quote
yes, see paul's post above!
PaulB2005
PostPosted: Fri Feb 13, 2009 2:03 pm    Post subject: Reply with quote
Yes, i described it in my above post. As you go through it adds up the distances and time so the last one tells you the totals.
greg_m
PostPosted: Sat Feb 14, 2009 1:17 am    Post subject: Reply with quote
my guide from above post works on my Garmin 255W, but you have to tap top bar (when next turn shows etc.), not 3D map. Then 'show map' and it shows you distance and time there. but I guess it might be slightly different from model to model.
22.062 (12 Jun 24)
