Darren Frequent Visitor
Posted: Mon Mar 01, 2004 6:01 pm Post subject: |
No If it aint broke then leave it be _________________ Darren Griffin |
a4ace Regular Visitor
Joined: 19/08/2003 21:28:03 Posts: 219 Location: Geneva, Switzerland
Posted: Mon Mar 01, 2004 7:21 pm Post subject: |
i asked because i want tomtom to automatically turn on bluetooth if it's off, which in my understanding the 2.09 accomplishes. though it could be tricky to not install the tomtom wizard.
i would like to try it, also the tomtom wizard, by backing up my pocketpc first but i had a problem the last time i restored. bluetooth won't startup. |
Posted: Mon Mar 01, 2004 7:29 pm Post subject: |
What model PPC are you using? There is a free utility to make the necessary registry mod to accomplish this that has been tested on h5550, h4150, h3870, h2210 and h1940.
It works fine but be aware that using this utility may affect the way other programs access BT Serial devices which may be an issue if you have a need for this and more than one BT Serial Device.
See here. _________________ Darren Griffin |
Posted: Mon Mar 01, 2004 8:13 pm Post subject: |
tried it but it did not turn bluetooth on |
Posted: Mon Mar 01, 2004 8:20 pm Post subject: |
Sorry I misunderstood you there. I don't think v2.09 will turn BT ON, what it will do is automatically connect to your BT GPS instead of having to select it in BT Manager. The link I provided achieves the same.
I'm not aware of any method to automatically turn ON BT if OFF when you launch TomTom. _________________ Darren Griffin |
Posted: Mon Mar 01, 2004 8:57 pm Post subject: |
hope we have this on pocketpc |
farwellbooth Regular Visitor
Joined: Mar 08, 2004 Posts: 62 Location: Portland, OR USA
Posted: Fri Mar 12, 2004 5:01 am Post subject: |
Will 2.09 prevent other BT programs such as MemoryMap Navigator running on a 4155? I'm new to all of this and have just recently purchased hardware and software and regret to read this...
Say I delete the recommended file... what functionality do I lose? I have to manually launch the GPS device for each application? thanks |
Posted: Fri Mar 12, 2004 10:32 am Post subject: |
v2.08 and v2.09 will by default prevent other apps from accessing the BT Com Port and this includes Memory-Map.
If you follow our guide and uninstall the ~TomTomGPS entry then you will lose no functionality except if you switch off your PPC before exiting TT then you will have to soft reset.
I personally have stuck with v2.07 available from here which has none of these issues and uses the BT browser so you have to manually choose which device you want to connect to when you launch TT. _________________ Darren Griffin |
gwrey Occasional Visitor
Joined: Apr 11, 2004 Posts: 1 Location: Riverview, FL USA
Posted: Sun Apr 11, 2004 7:58 pm Post subject: |
I tried everything posted here to get this to work and I never could, TomTom always held control of the com port.
I found a solution on another site and it fixed the problem for me. I am using a iPAQ 1945 w/ PPC 2003, TomTom ver 2 with GPS 2.08.
What i did was edit the registry to put the BT driver back to the PPC driver.
Here are the instructions:
1. Download a register editor (For example here)
2. Go to: HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SerialX, were X is the BT com port for your device
3. Click in the "Value Dll" and in the button "edit button". Change the value to "BtCeIf.dll".
4. Close the editor.
5. Do a soft reset to the IPAQ.
I did this and now everything works great, I can use TomTom and OziExplorer.
greg |
divit04 Occasional Visitor
Posted: Tue Apr 13, 2004 11:58 am Post subject: |
Just wanting you all to know that after endless searching and mailing with TT support I finally have my iPaq4150 working with TT3 and Intelligolf7. Thanks a lot to you all
I've installed GPS2.07 and didn't have to use any registry editors nor did I had to uninstall anything (settings-remove programs)
Let the fun begin!! |
bjornh Occasional Visitor
Joined: Feb 03, 2004 Posts: 28 Location: Sweden, Visby
Posted: Thu Apr 29, 2004 10:35 am Post subject: |
5. Do a soft reset to the IPAQ. |
I am using a iPAQ 3970 w/ PPC 2003, TomTom ver 3 with GPS 3.02
and have done this (Serial5) on my PPC and it works great!!!
I have used it with TTN 3.01, Crux_View and GPS Monitor witout any problems!
//Björn H |
robgs Occasional Visitor
Posted: Fri Apr 30, 2004 2:17 pm Post subject: |
I have an iPAQ 4150, Fortuna Clip-On BT GPS, TomTom (GPS 3.02) and have had the problem with TT hogging the BT stack. I tried removing TomTom ~ GPS but then the main app wouldn't start and the device hung!
I am pleased to report however that the registry hack works and I am now able to run TT, Memory-map etc.
On my setup, the outbound port was COM6 so I performed the steps detailed in earlier posts and all is now OK!
:D :D |
lhonour Occasional Visitor
Posted: Mon Jun 14, 2004 9:34 pm Post subject: BT TomTom GPS has passed on. |
Just incase anyone was counting my TomTom from Nov 03 has just died with the symptoms described above ie no longer has a blue light or perhaps just a quick blip as I am switching it on and then nothing. After spending the day switching it on and off I have had the benefit of finding this thread. The only question is what I did with those charts and maps. |
Skids Regular Visitor
Posted: Mon Nov 01, 2004 3:39 pm Post subject: |
Just for the record I uninstalled TomTom~GPS and installed Ver 2.07 and both TTN3 and GPS Tuner work with no problems.
I have tried 3.07 and it didn't make any difference
I have an HP Ipaq 4150 |
eliballdo Occasional Visitor
Posted: Fri Feb 23, 2007 1:45 am Post subject: STILL A PROBLEM |
Hi Dave,
Great forum here, let´see if anyone could solve this:
I´m using both, TOM TOM Navigator and Ozi Explorer on my Qtek S200. The thing is when select remove programs "TOM TOM^GPS" does not appear. Only "TOM TOM Navigator" and "TOM TOM TOM TOM". I already tried selecting "TOM TOM TOM TOM" and installing version 2.06 as suggested in Ozi official website, but not worked. On Ozi, when selecting the com port, com6 -that i use on TOM TOM and works perfectly, doesn´t appear in the list.
Any suggestion??
Thanks 4 ur time !! |
