uncle_knobbie Occasional Visitor
Posted: Sun Feb 08, 2009 12:58 am Post subject: Direction Indicator? |
Updated to 1.3.
Went for a walk, couldn't see the GPS direction indicator.
What does it look like, how do I get it on.
Thanks |
daveweth Occasional Visitor
Posted: Sun Feb 08, 2009 1:11 am Post subject: |
In Map mode, it's a short blue line extending from the outer edge of the blue position circle in the direction of travel. It only appears when you are moving. |
Bosun Frequent Visitor
Joined: May 02, 2005 Posts: 473 Location: Wakefield,West Riding of Yorkshire
Posted: Sun Feb 08, 2009 11:37 am Post subject: |
"It's where Dave sez"
However if you still can't see it you may have a faulty unit or the 1.3 firmware upgrade hasn't done it's job properly.
I am sure a call to Satmap will sort things if need be.
Ian |
LostMike Frequent Visitor
![](modules/Forums/images/avatars/18317326134dbc3e0165dbe.jpg)
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Sun Feb 08, 2009 11:43 am Post subject: |
When I first tried 1.3 I could not see the direction indicator but then I realised that I normally stop to refer to the A10 - so no motion!
Try walking at a brisk pace with it on and I am fairly sure you will see it. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
Golgotha Occasional Visitor
Posted: Mon Feb 09, 2009 9:39 am Post subject: |
I would be useful if the A10 flashed the direction indicator for a few seconds once motion has stopped. |
4ndynorfolk Regular Visitor
![](modules/Forums/images/avatars/gallery/1_satmap_active10.jpg)
Posted: Mon Feb 09, 2009 3:29 pm Post subject: |
I like the new feature,.
Surely, though, if you stop to look at your Satmap, the direction of travel is 180 degrees to the last section of breadcrumb trail. If you have only just changed direction, any method of indicator will be incorrect. |
