Pocket GPS World :: View topic - Nuvi Map Symbols
Nuvi Map Symbols
PeterSm
PostPosted: Wed Feb 04, 2009 11:02 pm    Post subject: Nuvi Map Symbols Reply with quote
Does anybody know if you can add additional icons to those that are used as the "Map Symbols" (i.e. those that you can assign to favorites using the "Change map Symbol" and look like small 10x10 icons)..
Regards
PeterSm.
PaulB2005
PostPosted: Thu Feb 05, 2009 9:51 am    Post subject: Reply with quote
The only way to change it is to save the Favourites as a POI file and then assign a BMP icon to the file.
You'd need a POI file for each differenticon you want to use.
To do this open NotePad and copy the following line into it
Longitude,Latitude,Name
Then enter your POIs in the following format
0.272040367,51.44316159,Bluewater
with each new one on a new line so the result should look like this
-1.3383,52.2714,Some Place
-1.4465635,51.45678,Somewhere
-0.224832,52.0694,Somewhere Else
Save the result as "MY POI.CSV" (without quotes) and make sure it's not called "MY POI.CSV.TXT", "MY POI.TXT.CSV" or "MY POI"
Then take your selected BMP icon and rename it to MY POI.BMP" (without quotes) It should be no bigger than 24 x 24 pixels
Place the 2 files in your POILoader upload folder with you other POIs and load them to the Nuvi.
PeterSm
PostPosted: Thu Feb 05, 2009 8:26 pm    Post subject: Reply with quote
Cheers..thought so!!!
22.071 (03 Jul 24)
