lyngarth Occasional Visitor
![](modules/Forums/images/avatars/gallery/simpsons12.jpg)
Posted: Fri Jan 30, 2009 6:51 pm Post subject: Problem in home |
Right I have just opened up home 2.5.2.60 to update and when there I thought I would put in a post code using "Operate My Go" button but I'm getting an error come up when I try to use this, the error is as follows..." this function is not yet supported for your navigation device or operating system"
Now I have a 920T with 8.320 and v815.2003 maps also running Vista, which I'm sure many others are using as well.
So was wondering if anyone knows how I can get this working again, as I have used it in the past.
Many thanks
Lyngarth
P.s Home is 2.5.2.60 |
Posted: Fri Jan 30, 2009 7:01 pm Post subject: |
The issue you have is that you are using 8,320 software on the device, Home expects to see 8,300 as the latest for your unit (unless you have the TomTom Work package).
You can roll back to the 8,300 by re-installing a backup or if you don't have one I can provide a link to the 8,300 release so you can put that back on the device and rediscover the stuttering voices and slow screen refresh rates
There are no updates other than Map Share currently available of any interest so why degrade the machine? But if you want 8,300 and a fully functional Home interface post back and I will put a link up as to where from - Mike |
Posted: Sat Jan 31, 2009 11:33 am Post subject: |
Thanks for the reply Mike, now I know why its not working I'm more than happy to stick with it as it is, was just wondering why it had stopped working.
Cheers for the info,
Lyngarth |
Posted: Sat Jan 31, 2009 11:55 am Post subject: |
When the next update is made available I guess I better add some more instructions to the thread about the stuttering voices and actually cover off how to update the unit as Home cannot see the device.
Its not difficult, but for people to update the device to get a new map once its released they will need to use the Home interface - Mike |
